Hi Dirk,
On 02/08/2018 07:23 AM, Dirk Zimoch wrote:
> Attached is a patch file for dbScan.c which should fix the problem and
> restore backward compatibility.
> I have created (and quickly tested) it with EPICS 7 but I guess it
> should work with 3.16 as well.
Please work against the 3.15 branch, since that was where we introduced
your named events work. We will merge it up into the later branches from
there.
> The hack is to treat "x.000000" and "x" as the same event name if x is
> an integer between 0 and 255. ("0" and "0.000000" are no event at all
> now just like "").
I don't like the string comparisons since they would silently break if
the number of decimal digits generated by the double → string conversion
gets changed.
Better to parse the string properly into a double — look at the
epicsParseDouble() routine declared in epicsStdlib.h and documented at
https://epics.anl.gov/base/R3-15/5-docs/AppDevGuide/libComOSIlibraries.html#x21-84700020.13
— then either round or truncate the fractional part.
- Andrew
- Re: Scanning on event number fails with EPICS 3.16 Dirk Zimoch
Re: Epics Core 7 & Submodules Hugo Slepicka
<2018>
2025
2026
<2018>
2025
2026
