2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics Core 7 & Submodules
To: Ralph Lange <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Thu, 08 Feb 2018 05:57:44 +0000
Hi Ralph,
Thanks a lot for all the explanation...
All makes sense now!
Cheers,
Hugo
On Wed, Feb 7, 2018 at 8:41 PM Ralph Lange <[email protected]> wrote:
1.
That repository (containing the full history of EPICS) is quite large.
In the current setup, you are able to have a single clone of that large repository, and check out the three branches into three different places.
If you separate out the modules into separate repositories, you will always have three copies of the large repository.
2.
We are heavily using the very powerful issue tracker on Launchpad. (E.g. one single issue being tracked separately in several EPICS release series.)
The GitHub issue tracker on the other hand is quite simple and limiting. (E.g. can't move an issue to a different repo.)
We don't see a way to losslessly export the issues from Launchpad and import them to GitHub.
Once there are solutions to these issues, we might want to reconsider the general repository layout.
Note that we are discussing to bring the three original Base parts back to be on a single branch to reduce complexity and avoid the unusual setup that seems to cause a lot of confusion.
Cheers,
~Ralph
On Thu, Feb 8, 2018 at 4:02 AM, Hugo Slepicka <[email protected]> wrote:
Hi Steven,
Thank you for the clarification on those guys.
Would it make sense in this case to have those 3 pieces to be parte of core/master and not "almost" separated modules?
Or if indeed they are to be separated submodules, we can find a way to move each one into a separated GitHub repository and move the history along with the code.
Cheers,
Hugo
Epics Core 7 & Submodules Hugo Slepicka
Re: Epics Core 7 & Submodules Hugo Slepicka
Re: Epics Core 7 & Submodules Ralph Lange
Prev: Re: Epics Core 7 & Submodules Ralph Lange
Next: Re: Scanning on event number fails with EPICS 3.16 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 08 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
