2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: bundling linenoise with base
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS Core-Talk <[email protected]>
Date: Fri, 9 Feb 2018 19:22:15 +0100
On 02/09/2018 07:04 PM, Johnson, Andrew N. wrote:
> Please check out the changes to epicsReadline in 3.16 (I think the
> code in 7.0 is the same but I might be wrong and that was where I did
> the work instead of 3.16). Your work may need some changes but I
> think the newer API may be what you’re looking for.
Thanks, will do.
> The RTEMS targets also have support for a library called libtecla
> which I believe provides some/similar functionality but I don’t know
> exactly what — Eric Norum added that way back.
It is much larger: 22 kLOC in 22 C files, whereas linenoise has just one
C file and one header and 820 LOC. I looked for a smaller and simpler
library because I did not want to spend much time learning how to
configure, build, and use libtecla.
> What is the license for linenoise? I have heard of it and it sounds
> like it might be a good fit.
Looks like a 2-clause standard BSD license [1].
[1] https://github.com/antirez/linenoise/blob/master/LICENSE
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
bundling linenoise with base Benjamin Franksen
Re: bundling linenoise with base Johnson, Andrew N.
Prev: Re: bundling linenoise with base Eric Norum
Next: Re: Scanning on event number fails with EPICS 3.16 Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: RE: bundling linenoise with base Laznovsky Michael (PSI)
ANJ, 15 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
