2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: bundling linenoise with base
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS Core-Talk <[email protected]>
Date: Fri, 9 Feb 2018 10:06:48 -0800
I think that Till added the libtecla stuff.
I did the original standalone and libreadline versions.
On Feb 9, 2018, at 10:04 AM, Johnson, Andrew N. <[email protected]> wrote:
Please check out the changes to epicsReadline in 3.16 (I think the code in 7.0 is the same but I might be wrong and that was where I did the work instead of 3.16). Your work may need some changes but I think the newer API may be what you’re looking for.
The RTEMS targets also have support for a library called libtecla which I believe provides some/similar functionality but I don’t know exactly what — Eric Norum added that way back.
bundling linenoise with base Benjamin Franksen
Re: bundling linenoise with base Johnson, Andrew N.
Prev: Re: bundling linenoise with base Johnson, Andrew N.
Next: Re: bundling linenoise with base Benjamin Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 09 Feb 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
