Hi Ernest,
On Sat, Feb 17, 2018 at 3:52 PM, Williams Jr., Ernest L. <[email protected]> wrote:
First of all: obviously, Channel Access filters are part of EPICS 7 - i.e., the API is in Base, and all filters provided with Base still work with no changes. So, assuming that your question is about using server-side filters with pvAccess - what exactly is your use case? Do you have existing specific locally developed filter code that you want to use through pvAccess? Are you using a specific functionality provided by a filter from Base that is not available using pvAccess? Cheers, ~Ralph
| ANJ, 17 Feb 2018 |
Home
News
About
Talk
Base
Modules
Extensions
