2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-master-windows » STATIC,win32 #34
To: [email protected]
Date: Sun, 25 Feb 2018 01:40:40 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/34/display/redirect>
Started by upstream project "epics-master-windows" build number 34
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/>
 > C:/Program Files (x86)/Git/bin/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files (x86)/Git/bin/git.exe config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
 > C:/Program Files (x86)/Git/bin/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files (x86)/Git/bin/git.exe fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base/
	at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:862)
	at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1129)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1160)
	at hudson.scm.SCM.checkout(SCM.java:495)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1202)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
	at hudson.model.Run.execute(Run.java:1724)
	at hudson.matrix.MatrixRun.run(MatrixRun.java:146)
	at hudson.model.ResourceController.execute(ResourceController.java:97)
	at hudson.model.Executor.run(Executor.java:429)
Caused by: hudson.plugins.git.GitException: Command "C:/Program Files (x86)/Git/bin/git.exe fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*" returned status code 1:
stdout: Fetching submodule modules/ca
Fetching submodule modules/database
Fetching submodule modules/libcom
Fetching submodule modules/pvAccess
Fetching submodule modules/pvData
Fetching submodule modules/pva2pva
stderr: remote: Counting objects: 86, done.
remote: Compressing objects:   1% (1/86)   remote: Compressing objects:   2% (2/86)   remote: Compressing objects:   3% (3/86)   remote: Compressing objects:   4% (4/86)   remote: Compressing objects:   5% (5/86)   remote: Compressing objects:   6% (6/86)   remote: Compressing objects:   8% (7/86)   remote: Compressing objects:   9% (8/86)   remote: Compressing objects:  10% (9/86)   remote: Compressing objects:  11% (10/86)   remote: Compressing objects:  12% (11/86)   remote: Compressing objects:  13% (12/86)   remote: Compressing objects:  15% (13/86)   remote: Compressing objects:  16% (14/86)   remote: Compressing objects:  17% (15/86)   remote: Compressing objects:  18% (16/86)   remote: Compressing objects:  19% (17/86)   remote: Compressing objects:  20% (18/86)   remote: Compressing objects:  22% (19/86)   remote: Compressing objects:  23% (20/86)   remote: Compressing objects:  24% (21/86)   remote: Compressing objects:  25% (22/86)   remote: Compressing objects:  26% (23/86)   remote: Compressing objects:  27% (24/86)   remote: Compressing objects:  29% (25/86)   remote: Compressing objects:  30% (26/86)   remote: Compressing objects:  31% (27/86)   remote: Compressing objects:  32% (28/86)   remote: Compressing objects:  33% (29/86)   remote: Compressing objects:  34% (30/86)   remote: Compressing objects:  36% (31/86)   remote: Compressing objects:  37% (32/86)   remote: Compressing objects:  38% (33/86)   remote: Compressing objects:  39% (34/86)   remote: Compressing objects:  40% (35/86)   remote: Compressing objects:  41% (36/86)   remote: Compressing objects:  43% (37/86)   remote: Compressing objects:  44% (38/86)   remote: Compressing objects:  45% (39/86)   remote: Compressing objects:  46% (40/86)   remote: Compressing objects:  47% (41/86)   remote: Compressing objects:  48% (42/86)   remote: Compressing objects:  50% (43/86)   remote: Compressing objects:  51% (44/86)   remote: Compressing objects:  52% (45/86)   remote: Compressing objects:  53% (46/86)   remote: Compressing objects:  54% (47/86)   remote: Compressing objects:  55% (48/86)   remote: Compressing objects:  56% (49/86)   remote: Compressing objects:  58% (50/86)   remote: Compressing objects:  59% (51/86)   remote: Compressing objects:  60% (52/86)   remote: Compressing objects:  61% (53/86)   remote: Compressing objects:  62% (54/86)   remote: Compressing objects:  63% (55/86)   remote: Compressing objects:  65% (56/86)   remote: Compressing objects:  66% (57/86)   remote: Compressing objects:  67% (58/86)   remote: Compressing objects:  68% (59/86)   remote: Compressing objects:  69% (60/86)   remote: Compressing objects:  70% (61/86)   remote: Compressing objects:  72% (62/86)   remote: Compressing objects:  73% (63/86)   remote: Compressing objects:  74% (64/86)   remote: Compressing objects:  75% (65/86)   remote: Compressing objects:  76% (66/86)   remote: Compressing objects:  77% (67/86)   remote: Compressing objects:  79% (68/86)   remote: Compressing objects:  80% (69/86)   remote: Compressing objects:  81% (70/86)   remote: Compressing objects:  82% (71/86)   remote: Compressing objects:  83% (72/86)   remote: Compressing objects:  84% (73/86)   remote: Compressing objects:  86% (74/86)   remote: Compressing objects:  87% (75/86)   remote: Compressing objects:  88% (76/86)   remote: Compressing objects:  89% (77/86)   remote: Compressing objects:  90% (78/86)   remote: Compressing objects:  91% (79/86)   remote: Compressing objects:  93% (80/86)   remote: Compressing objects:  94% (81/86)   remote: Compressing objects:  95% (82/86)   remote: Compressing objects:  96% (83/86)   remote: Compressing objects:  97% (84/86)   remote: Compressing objects:  98% (85/86)   remote: Compressing objects: 100% (86/86)   remote: Compressing objects: 100% (86/86), done.
remote: Total 86 (delta 70), reused 0 (delta 0)
From https://git.launchpad.net/epics-base
   de442e9..ac4d5c9  3.14       -> origin/3.14
   61296b8..c18b6f2  3.15       -> origin/3.15
   cd8fd8a..2921414  3.16       -> origin/3.16
   eb683aa..1beafdf  ca/master  -> origin/ca/master
   d550b9d..57acac8  core/master -> origin/core/master
   a4f0722..0e0a919  database/master -> origin/database/master
   dd15a27..ca0149a  libcom/master -> origin/libcom/master
 * [new tag]         R3.14.12.7 -> R3.14.12.7
fatal: bad object 1beafdf7e5633d255bc1776b48b40d0836a1a3b5
fatal: bad object 0e0a919567b0d98f653589ae95bccba769fb0dd8
fatal: bad object ca0149ab92f99b31e15c3df8ccd6db4445997398
fatal: unable to access 'https://github.com/epics-base/pvAccessCPP/': error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
fatal: unable to access 'https://github.com/epics-base/pvDataCPP/': error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
fatal: unable to access 'https://github.com/epics-base/pva2pva/': error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1996)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1715)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:72)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:405)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
	at hudson.remoting.UserRequest.perform(UserRequest.java:207)
	at hudson.remoting.UserRequest.perform(UserRequest.java:53)
	at hudson.remoting.Request$2.run(Request.java:358)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
	Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win32-1
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1693)
		at hudson.remoting.UserResponse.retrieve(UserRequest.java:310)
		at hudson.remoting.Channel.call(Channel.java:908)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
		at sun.reflect.GeneratedMethodAccessor3893.invoke(Unknown Source)
		at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
		at java.lang.reflect.Method.invoke(Method.java:498)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
		at com.sun.proxy.$Proxy96.execute(Unknown Source)
		at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:860)
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-master-windows » STATIC,win32 #35 APS Jenkins
Prev: Build failed in Jenkins: epics-master-windows » DLL,win64 #34 APS Jenkins
Next: Jenkins build is back to stable : epics-master » linux64 #44 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-master-windows » DLL,win64 #37 APS Jenkins
Next: Build failed in Jenkins: epics-master-windows » STATIC,win32 #35 APS Jenkins
ANJ, 01 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
