Subject: |
Build failed in Jenkins: epics-master-windows » STATIC,win32 #35 |
APS Jenkins <[email protected]> |
To: |
[email protected] |
Date: |
Sun, 25 Feb 2018 15:54:07 -0600 (CST) |
See <https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/35/display/redirect>
Started by upstream project "epics-master-windows" build number 35
originally caused by:
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win32-1 (win32) in workspace <https://jenkins.aps.anl.gov/job/epics-master-windows/LIBRARIES=STATIC,OS=win32/ws/>
> C:/Program Files (x86)/Git/bin/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> C:/Program Files (x86)/Git/bin/git.exe config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
> C:/Program Files (x86)/Git/bin/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
> C:/Program Files (x86)/Git/bin/git.exe fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*
Checking out Revision 57acac8fb8d2357adfb6f3e375bce4988b84acb9 (refs/remotes/origin/core/master)
> C:/Program Files (x86)/Git/bin/git.exe config core.sparsecheckout # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe checkout -f 57acac8fb8d2357adfb6f3e375bce4988b84acb9
Commit message: "Update all PVA modules to branch tip"
> C:/Program Files (x86)/Git/bin/git.exe rev-list --no-walk d550b9d55c67fd4ba7397f40f9d2aa5fa6643ddc # timeout=10
Cleaning workspace
> C:/Program Files (x86)/Git/bin/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
> C:/Program Files (x86)/Git/bin/git.exe reset --hard # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe clean -fdx # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe submodule foreach --recursive git reset --hard # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe submodule foreach git clean -fdx # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe remote # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe submodule init # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe submodule sync # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe config --get remote.origin.url # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/libcom.url # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/libcom.path # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/libcom
> C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/database.url # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/database.path # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/database
> C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/ca.url # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/ca.path # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/ca
> C:/Program Files (x86)/Git/bin/git.exe config --get submodule.modules/pvData.url # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
> C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/pvData
Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win32-1
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1693)
at hudson.remoting.UserResponse.retrieve(UserRequest.java:310)
at hudson.remoting.Channel.call(Channel.java:908)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
at com.sun.proxy.$Proxy110.execute(Unknown Source)
at hudson.plugins.git.extensions.impl.SubmoduleOption.onCheckoutCompleted(SubmoduleOption.java:108)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1238)
at hudson.scm.SCM.checkout(SCM.java:495)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1202)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1724)
at hudson.matrix.MatrixRun.run(MatrixRun.java:146)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
hudson.plugins.git.GitException: Command "C:/Program Files (x86)/Git/bin/git.exe submodule update --remote modules/pvData" returned status code 1:
stdout:
stderr: fatal: unable to access 'https://github.com/epics-base/pvDataCPP/': error:1407742E:SSL routines:SSL23_GET_SERVER_HELLO:tlsv1 alert protocol version
Unable to fetch in submodule path 'modules/pvData'
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:1996)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1715)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:72)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$7.execute(CliGitAPIImpl.java:1161)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
at hudson.remoting.UserRequest.perform(UserRequest.java:207)
at hudson.remoting.UserRequest.perform(UserRequest.java:53)
at hudson.remoting.Request$2.run(Request.java:358)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused: java.io.IOException: Could not perform submodule update
at hudson.plugins.git.extensions.impl.SubmoduleOption.onCheckoutCompleted(SubmoduleOption.java:113)
[WARNINGS] Skipping publisher since build result is FAILURE
- Build failed in Jenkins: epics-master-windows » STATIC,win32 #36 APS Jenkins
- Build failed in Jenkins: epics-master-windows » STATIC,win32 #34 APS Jenkins
Build failed in Jenkins: epics-master-windows » STATIC,win64 #35 APS Jenkins
Build failed in Jenkins: epics-master-windows » DLL,win64 #35 APS Jenkins
<2018>
2025
2026
<2018>
2025
2026
ANJ, 26 Feb 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
