2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Conversion from hex number string to LONG-type field
To: <[email protected]>
Date: Wed, 28 Feb 2018 12:47:21 -0600
Hi Bruno,
On 02/28/2018 10:27 AM, Bruno Martins wrote:
> I noticed that dbpf doesn't convert hex values to fields with type LONG.
> Digging through the code it seems that the culprit is in
> ioc/db/dbFastLinkConv.c: cvt_st_l (and a bunch others) calls strtol with
> base=10. Wouldn't it be better to call it with base=0 and let it figure
> out the proper base? Or, instead, to use epicsScanDouble like cvt_st_ul
> does?
The dbFastLinkConv.c routines are also used for data conversions between
records, and making this change could potentially break existing
databases that relied on the original behaviour. I admit it's an obscure
behaviour, but I am generally very reluctant to accept changes that
alter what existing IOC databases actually do.
In particular a database that gets a number from a string that has
leading zeros would then be converted as an octal number (010 → 8)
instead of the decimal that it currently uses (010 → 10).
I don't have a solution to that, discussion and ideas welcome.
- Andrew
Conversion from hex number string to LONG-type field Bruno Martins
Prev: Re: Named Event, TSE and GeneralTime Michael Davidsaver
Next: Re: Understanding the GIT organization and workflow for EPICS 7 Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Conversion from hex number string to LONG-type field Bruno Martins
Next: New/improved iocsh debug utility functions Dirk Zimoch
ANJ, 01 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
