2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: New/improved iocsh debug utility functions (dbli)
To: <[email protected]>
Date: Fri, 2 Mar 2018 17:03:28 +0100
I could fix the problem that infos may appear on the alias dbRecordNode, but to allow 'caget alias.info' I needed dbRecordNode.aliasedRecnode which Michael introduced in 3.16(?). Thus it would make sense to implement CA to info fields in 3.16+ only, right? For my tests, I have simple back-ported aliasedRecnode to 3.14.12.7.
Dirk
On 02.03.2018 11:31, Dirk Zimoch wrote:
One thing is a bit confusing at them moment:
When a record has infos and aliases, the infos are bound to the previous alias, not to the original record:
record (ai, "dz:ai")
  alias("alias1")
  info(my_info_field, "Hello World")
  alias("alias2")
alias("dz:ai","alias3")
epics> dbla
alias1 --> dz:ai
alias2 --> dz:ai
alias3 --> dz:ai
epics> dbli
alias1.my_info_field "Hello World"
$ caget dz:ai.my_info_field
Channel connect timed out: 'dz:ai.my_info_field' not found.
$ /usr/local/epics/base/bin/SL6-x86_64/caget alias1.my_info_field
alias1.my_info_field           Hello World
$ /usr/local/epics/base/bin/SL6-x86_64/caget alias2.my_info_field
Channel connect timed out: 'alias2.my_info_field' not found.
$ /usr/local/epics/base/bin/SL6-x86_64/caget alias3.my_info_field
Channel connect timed out: 'alias3.my_info_field' not found.
Need to fix that...
Re: New/improved iocsh debug utility functions (dbli) Dirk Zimoch
New/improved iocsh debug utility functions Dirk Zimoch
Re: New/improved iocsh debug utility functions Andrew Johnson
Prev: Re: MSI Makefile Madness Konrad, Martin
Next: Build failed in Jenkins: epics-base-3.15-win64 #340 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: New/improved iocsh debug utility functions (dbli) Dirk Zimoch
Next: Re: New/improved iocsh debug utility functions (dbli) Dirk Zimoch
ANJ, 08 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
