2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MSI Makefile Madness
To: EPICS core-talk <[email protected]>
Date: Fri, 2 Mar 2018 14:18:43 +0000
Hi Michael,
You got to be careful with your file names. IIRC the EPICS build system
contains rules that automatically expand templates and substitution
files using MSI as follows:
.substitutions -> .db
.template -> .db
The ".template" extension is only required if your file is using
"substitute" and "include". If your files don't contain these keywords
".db" would probably be a better choice. If you use these keywords you
probably want to refer to "foo.db" in your substitution file to include
the already expanded file.
That being said, the following works as expected:
$ grep DB Makefile
DB += file.db
$ cat file.substitutions
file "other1.db" {
{X=1}
file "other2.db" {
{X=2}
$ cat other1.db
# from file.template $(X)
$ cat other2.db
# from other.template $(X)
$ make -C ../../ distclean all
$ cat ../../db/file.db
# from file.template 1
# from other.template 2
HTH,
Martin
Martin Konrad
High Performance Controls Team Leader
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
Re: MSI Makefile Madness Bruce Hill
Prev: Re: New/improved iocsh debug utility functions (dbli) Dirk Zimoch
Next: Re: New/improved iocsh debug utility functions (dbli) Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: MSI Makefile Madness Michael Davidsaver
Next: Re: MSI Makefile Madness Bruce Hill
ANJ, 06 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
