We ran into this issue as well.
It happens when you have both foo.substitutions and foo.template
in your Db directory and want msi to create and install foo.db.
Note that you can't rename foo.template to foo.db as it will just
get
installed w/o any msi expansion.
The problem in my view is that msi ignores all filenames specified
in the
substitutions file if a template filename is passed as an argument
to msi.
This is a deliberate choice in msi as we can see from the
documentation.
dbLoadTemplate Format
This format is an extension of the format accepted by the EPICS
IOC command
dbLoadTemplate, and allows templates to be expanded on
the host rather
by using dbLoadTemplate at IOC boot time.
global {gbl_var1=gbl_val1, gbl_var2=gbl_val2, ...}
file templatefile {
pattern format or regular format
file "${WHERE}/template2" {
For the dbTemplate format, the template filename does not have
to be given
on the command line, and is usually specified in the
substitutions file
instead. If a template filename is given on the command line it
will override
the filenames listed in the substitutions files.
We fixed this by changing our RULES.Db after verifying that we had
no use
cases that relied on the above behavior. Another possible fix
would be to
modify msi to respect filenames specified in the substitutions file
and only
use a command line template argument for the pattern and regular
formats
which don't specify a filename.
Here's the patch we use for RULES.Db:
% git diff fb5f13f^!
diff --git a/configure/RULES.Db b/configure/RULES.Db
index 7836d28..2d59529 100644
--- a/configure/RULES.Db
+++ b/configure/RULES.Db
@@ -467,13 +467,13 @@ $(COMMON_DIR)/%.db: $(COMMON_DIR)/%.edf
$(COMMON_DIR)/%.db: %$(SUBST_SUFFIX)
$(ECHO) "Inflating database from $< $(TEMPLATE_FILENAME)"
@$(RM) $(notdir $@)
- $(MSI3_15) $(DBFLAGS) -o $(notdir $@) -S$<
+ $(MSI3_15) $(DBFLAGS) -o $(notdir $@) -S$<
@$(MV) $(notdir $@) $@
$(COMMON_DIR)/%.db: ../%$(SUBST_SUFFIX)
@$(RM) $(notdir $@)
$(COMMON_DIR)/%.db: %$(TEMPL_SUFFIX)
Cheers,
- Bruce
On 03/02/2018 06:18 AM, Konrad, Martin
wrote:
Hi Michael,
You got to be careful with your file names. IIRC the EPICS build system
contains rules that automatically expand templates and substitution
files using MSI as follows:
.substitutions -> .db
.template -> .db
The ".template" extension is only required if your file is using
"substitute" and "include". If your files don't contain these keywords
".db" would probably be a better choice. If you use these keywords you
probably want to refer to "foo.db" in your substitution file to include
the already expanded file.
That being said, the following works as expected:
$ grep DB Makefile
DB += file.db
$ cat file.substitutions
file "other1.db" {
{X=1}
file "other2.db" {
{X=2}
$ cat other1.db
# from file.template $(X)
$ cat other2.db
# from other.template $(X)
$ make -C ../../ distclean all
$ cat ../../db/file.db
# from file.template 1
# from other.template 2
HTH,
Martin
Bruce Hill
Member Technical Staff
SLAC National Accelerator Lab
2575 Sand Hill Road M/S 10
Menlo Park, CA 94025
- Re: MSI Makefile Madness Benjamin Franksen
- Re: MSI Makefile Madness Konrad, Martin
Build failed in Jenkins: epics-base-3.16-win64s-test #165 APS Jenkins
Jenkins build is back to normal : epics-base-3.16-win64s-test #166 APS Jenkins
<2018>
2025
2026
<2018>
2025
2026
ANJ, 09 Apr 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
