2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MSI Makefile Madness
To: Bruce Hill <[email protected]>, <[email protected]>
Date: Mon, 9 Apr 2018 13:58:48 +0200
On 03/06/2018 11:11 PM, Bruce Hill wrote:
> We ran into this issue as well.
> It happens when you have both foo.substitutions and foo.template
> in your Db directory and want msi to create and install foo.db.
> Note that you can't rename foo.template to foo.db as it will just get
> installed w/o any msi expansion.
> The problem in my view is that msi ignores all filenames specified in the
> substitutions file if a template filename is passed as an argument to msi.
> This is a deliberate choice in msi as we can see from the documentation.
>>       dbLoadTemplate Format
>> This format is an extension of the format accepted by the EPICS IOC
>> command dbLoadTemplate, and allows templates to be expanded on the
>> host rather by using dbLoadTemplate at IOC boot time.
>>     global {gbl_var1=gbl_val1, gbl_var2=gbl_val2, ...}
>>     file templatefile {
>>          /pattern format or regular format/
>>     file "${WHERE}/template2" {
>> For the dbTemplate format, the template filename does not have to be
>> given on the command line, and is usually specified in the
>> substitutions file instead. If a template filename is given on the
>> command line it will override the filenames listed in the
>> substitutions files.
> We fixed this by changing our RULES.Db after verifying that we had no use
> cases that relied on the above behavior.
Same here. These are the rules we use, including proper generation of
dependencies to be included by the Makefile:
DEPENDS+=$(patsubst %,%$(RAW)$(DEP),$(COMMON_DBS))
$(COMMON_DIR)/%.template$(DEP): %.substitutions
	$(ECHO) "Generating database dependencies from $(<F)"
	$(PERL) -e 'undef $$/; $$_=<>; @d=m/(?:^|})\s*file\s+([^{\s]*)\s*\{/mg;
print "$(COMMON_DIR)/$*.template: @d\n";' $< > $(@F).tmp
	$(MV) $(@F).tmp $@
$(COMMON_DIR)/%.db$(RAW)$(DEP): %.substitutions
print "$(COMMON_DIR)/$*.db$(RAW): @d\n";' $< > $(@F).tmp
	$(MV) $(@F).tmp $@
$(COMMON_DIR)/%.db$(RAW): %.substitutions
	$(ECHO) "Inflating database from $(<F)"
	$(MSI) $(DBFLAGS) -S$< > $(@F).tmp
	$(MV) $(@F).tmp $@
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
Re: MSI Makefile Madness Konrad, Martin
Re: MSI Makefile Madness Bruce Hill
Prev: Re: pvaccess and Java 9 Re: PVA Java status Eric Berryman
Next: Re: bundling linenoise with base Benjamin Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: MSI Makefile Madness Bruce Hill
Next: Build failed in Jenkins: epics-base-3.15-win64 #340 APS Jenkins
ANJ, 09 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
