2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: bundling linenoise with base
To: "Laznovsky Michael (PSI)" <[email protected]>, EPICS Core-Talk <[email protected]>
Date: Mon, 9 Apr 2018 15:11:32 +0200
On 03/15/2018 05:15 PM, Laznovsky Michael (PSI) wrote:
> Hi Ben- just a belated comment... I took a look at linenoise, and apparently it does
> malloc/memmove/realloc (and expects the caller to free() each line of input)...is that
> something you want in EPICS?  Hasn't that been a problem in the past in other areas?
> Perhaps not a big deal for relatively low-traffic console input, but may be one of
> those things that can creep up on you later, if eg. a large amount of input is piped
> in or something.
AFAIU, when input is redirected (in or out), EPICS automatically
switches to a "dumb mode" that circumvents any EPICS_READLINE
functionality, however implemented.
Anyway, it turned out that using linenoise has another disadvantage, at
least with the way we set up our IOCs: The log files stored by the
conserver daemon now contain all the control codes and repeated
rendering of the command line, which makes them nearly unreadable for
us. This is why I have, for the moment, abandoned the idea. It might be
possible to work around this issue with a filter somewhere that
understands and interprets all the control codes, too. This requires
duplicating the work that is done by (and the code implementing) the
linenoise (or any other) command line library, which is why I don't
particularly like the idea.
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
bundling linenoise with base Benjamin Franksen
RE: bundling linenoise with base Laznovsky Michael (PSI)
Prev: Re: MSI Makefile Madness Benjamin Franksen
Next: Re: EPICS R3.15.5 Patches slated for the "Known Problems" Page. Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: bundling linenoise with base Laznovsky Michael (PSI)
Next: Re: EPICS 7 Documentation or just README.examples for the V4 part. Williams Jr., Ernest L.
ANJ, 11 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
