2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pvaccess and Java 9 Re: PVA Java status
To: "Kasemir, Kay" <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Fri, 30 Mar 2018 15:19:48 -0400
As Kunal mentioned, Corba is marked for removal.
I was just talking with Dylan, and he mentioned Corba will be removed in Java 11 (which is out in 6 months).
I thought I would share the date.
Thank you!
Eric
On Tue, Mar 27, 2018 at 1:37 PM, Kasemir, Kay <[email protected]> wrote:
Hi:
> .. we are simply using some of the packages with the name "corba"
> https://docs.oracle.com/javase/9/docs/api/java.corba-summary.html
> .. is marked for removal ..
Looks like that java.corba is still there, but by default not used.
For the time being, Java 9 can execute the pvAccessJava code when you add
    --add-modules=java.corba
to the java command line to add that module back in.
-Kay
PVA Java status Timo Korhonen
Re: PVA Java status Kasemir, Kay
Re: PVA Java status Timo Korhonen
pvaccess and Java 9 Re: PVA Java status Kasemir, Kay
RE: pvaccess and Java 9 Re: PVA Java status Shroff, Kunal
Re: pvaccess and Java 9 Re: PVA Java status Kasemir, Kay
Prev: Re: pull requests for new epics base structure (submodules) Ralph Lange
Next: Re: MSI Makefile Madness Benjamin Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pvaccess and Java 9 Re: PVA Java status Kasemir, Kay
Next: Normative types (again...) Timo Korhonen
ANJ, 13 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
