2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pull requests for new epics base structure (submodules)
To: EPICS Core-Talk <[email protected]>
Date: Thu, 29 Mar 2018 09:47:42 +0200
Hallo Heinz,
Original EPICS Base (the "classic" modules) are on Launchpad.
New PVA modules (formerly "V4") are on GitHub.
It's been that way for a while, and currently we are not planning to change.
I can’t push to github.com/epics-base/pvDatabaseCPP as user hjunkes
I just added you to the C++-devs group of the epics-base organization. Now you can.
trying to push libcom-branch hj/rtems5libcom to origin:git://git.launchpad.net/epics-base
Please do not push merge proposals to the epics-base master repo.
Instead, push merge proposals to your own repo, either in you personal Launchpad area (only you can push to it) or in the epics-base area (all epics-base members can push to it).
E.g. (using the second option)
Pull-URL (no authN, read-only):
Push-URL (authenticated, read/write):
Then (using the web interface) browse to the branch you want to propose, and create the merge proposal (make sure to direct it to the right branch in the epics-base master repo).
HTH,
~Ralph
pull requests for new epics base structure (submodules) Heinz Junkes
Re: pull requests for new epics base structure (submodules) Michael Davidsaver
Re: pull requests for new epics base structure (submodules) Heinz Junkes
Prev: Re: pull requests for new epics base structure (submodules) Heinz Junkes
Next: Re: pvaccess and Java 9 Re: PVA Java status Eric Berryman
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS R3.15.5 Patches slated for the "Known Problems" Page. Williams Jr., Ernest L.
ANJ, 30 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
