2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: MSI Makefile Madness
To: EPICS core-talk <[email protected]>
Date: Thu, 1 Mar 2018 20:18:59 -0800
So I've step into something which might be at least in part a feature,
but contains some elements which really aren't helpful.
The setup is this, a Makefile file containing
> DB += file.db
This directory also contains three files.
* file.substitutions
* file.template
* other.template
So two with the same basename.
> $ cat file.substitutions
> file "file.template" {
> {X=1}
> file "other.template" {
> {X=2}
> $ cat file.template
> # from file.template
> $ cat other.template
> # from other.template
What I expect to see is
> $ cat file.db
> # from file.template 1
> # from other.template 2
What I actually see is
> $ cat file.db
> # from file.template 2
msi completes normally.  No warnings are printed.
The second filename 'other.template' is silently ignored!
In fact, I find that all the filenames in the .substitutions
file are ignored!  So 'file "invalid" {' produces the same
output, and emits no warnings.
However, 'filexxx "invalid" {' triggers a syntax error as it should.
I've reduced this to a difference in how msi is called.
The unexpected comes from:
> msi -I. -o file.db -Sfile.substitutions file.template
If I renamed 'file.template' to eg. 'filex.template' then
the invocation is:
which produces the expected results.
So the immediate solution is to rename the .template file.
I am curious though to find out how much of this is defined,
or at least expected behavior?
Prev: Re: New/improved iocsh debug utility functions Andrew Johnson
Next: Re: New/improved iocsh debug utility functions (dbla) Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: New/improved iocsh debug utility functions (dbli) Dirk Zimoch
Next: Re: MSI Makefile Madness Konrad, Martin
ANJ, 09 Mar 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
