See <https://jenkins.aps.anl.gov/job/epics-base-3.16-mac-test/195/display/redirect>
Started by upstream project "epics-base-3.16-mac" build number 206
originally caused by:
Started by upstream project "epics-base-3.16" build number 209
Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on mac-1 (mac) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-mac-test/ws/>
[epics-base-3.16-mac] $ /bin/sh -xe /var/folders/6f/2q91ldsx2rncqbx80st_4r700000gn/T/jenkins8178262190328165417.sh
+ make -s clean-tests CROSS_COMPILER_TARGET_ARCHS=
+ ulimit -c unlimited
+ make -sj tapfiles CROSS_COMPILER_TARGET_ARCHS=
log client: connected to log server at "127.0.0.1:62214"
epicsEventDestroy: pthread_mutex_destroy failed: Invalid argument
epicsAtomicTest(56396,0x700000081000) malloc: *** error for object 0x7f83e04002a0: pointer being freed was not allocated
*** set a breakpoint in malloc_error_break to debug
/bin/sh: line 1: 56396 Abort trap: 6 perl -CSD epicsAtomicTest.t -tap > epicsAtomicTest.tap
Starting iocInit
chfConfigParseStart: plugin pvt alloc failed
Starting iocInit
dbConvertJSON: parse error: trailing garbage
0x10
(right here) ------^
0x10
0x10
0x10
0x10
0x10
0x10
0x10
dbJLinkInit: lexical error: invalid char in json text.
{"x":bbbb}
dbJLinkInit: parse error: premature EOF
{"z":{"good":6}
+ make -s test-results CROSS_COMPILER_TARGET_ARCHS=
Base.tap ........ ok
Breaktable.tap .. ok
DBD.tap ......... ok
Device.tap ...... ok
Driver.tap ...... ok
Function.tap .... ok
macLib.tap ...... ok
Menu.tap ........ ok
Recfield.tap .... ok
Recordtype.tap .. ok
Registrar.tap ... ok
Snippets.tap .... ok
Variable.tap .... ok
All tests successful.
Files=13, Tests=351, 0 wallclock secs ( 0.06 usr 0.02 sys + 0.01 cusr 0.01 csys = 0.10 CPU)
Result: PASS
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap ..........
Failed 21/50 subtests
macDefExpandTest.tap ......... ok
cvtFastTest.tap .............. ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
yajlTest.tap ................. ok
Test Summary Report
epicsAtomicTest.tap (Wstat: 0 Tests: 29 Failed: 0)
Parse errors: Bad plan. You planned 50 tests but ran 29.
Files=40, Tests=4014, 1 wallclock secs ( 0.29 usr 0.05 sys + 0.04 cusr 0.06 csys = 0.44 CPU)
Result: FAIL
../../../../configure/RULES_BUILD:356: recipe for target 'test-results' failed
make[3]: *** [test-results] Error 1
../../../configure/RULES_ARCHS:58: recipe for target 'test-results.darwin-x86' failed
make[2]: *** [test-results.darwin-x86] Error 2
../configure/RULES_DIRS:84: recipe for target 'libCom/test.test-results' failed
make[1]: *** [libCom/test.test-results] Error 2
configure/RULES_DIRS:84: recipe for target 'src.test-results' failed
make: *** [src.test-results] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: src/**/O.darwin-x86/*.tap
Saving reports...
TAP Reports Processing: FINISH
- Jenkins build is back to normal : epics-base-3.16-mac-test #196 APS Jenkins
Jenkins build is back to normal : epics-base-3.16-win32-test #159 APS Jenkins
Build failed in Jenkins: epics-base-3.16-test #86 APS Jenkins
<2018>
2025
2026
<2018>
2025
2026
