2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "Invalid request" for simply "pvget ThePV" when all other requests seem fine
To: "Kasemir, Kay" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 28 Aug 2018 12:52:16 -0500
On 08/28/2018 11:53 AM, Kasemir, Kay wrote:
> Looking further, the difference in pvget seems to be that a plain
> pvget ThePV now always seems to be the same as pvget -r
> 'field(value)' ThePV
> That works for most normative types that have a "value" as a
> top-level field, but can of course fail for a custom structure.
> In the past, pvget was more lenient. Maybe it checked the structure
> description, and if there's no "value", it would drop back to
> performing a "-r field()" request?
Last year Michael changed the pvget and pvput tools to use his new
pva/client.h API, but I don't see any evidence that he changed the
default pvRequest string, "field(value)" seems to have always been the
default. It may be though that if you didn't provide one with -r it just
sent an empty structure.
> I could argue either way:
> a) "pvget" without "-r .." should assume that we're reading a
> normative type, i.e. use "field(value)" and fail if there is no
> value.
> b) "pvget" should get something. First try "value", but if the PV
> info doesn't show a value field, just dump everything.
What does your older pvget show for its help text? The new one tells us
that it defaults to using 'field(value)', but this change in behaviour
looks like a regression now that you point it out.
> tux% pvget -h
> Usage: pvget [options] <PV name>...
> options:
>   -h: Help: Print this message
>   -V: Print version and exit
>   -r <pv request>:   Request, specifies what fields to return and options,
> default is 'field(value)'
>   -w <sec>:          Wait time, specifies timeout, default is 3 seconds for
> get, inf. for monitor
>   -t:                Terse mode - print only value, without names
>   -i:                Do not format standard types (enum_t, time_t, ...)
>   -m:                Monitor mode
>   -p <provider>:     Set default provider name, default is 'pva'
>   -v:                Show entire structure
>   -q:                Quiet mode, print only error messages
>   -d:                Enable debug output
>   -F <ofs>:          Use <ofs> as an alternate output field separator
>   -f <input file>:   Use <input file> as an input that provides a list PV
> name(s) to be read, use '-' for stdin
>  enum format:
>   -n: Force enum interpretation of values as numbers (default is enum string)
> example: pvget double01
I have added a link to this thread as a discussion point on the agenda
for next week. It would be helpful if you could have temporarily modify
your server to print out the pvRequest that it gets from the older pvget
just to confirm whether pvget used to send an empty object.
- Andrew
Re: "Invalid request" for simply "pvget ThePV" when all other requests seem fine Kasemir, Kay
Re: "Invalid request" for simply "pvget ThePV" when all other requests seem fine Andrew Johnson
Prev: Re: "Invalid request" for simply "pvget ThePV" when all other requests seem fine Kasemir, Kay
Next: Re: "Invalid request" for simply "pvget ThePV" when all other requests seem fine Kasemir, Kay
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 28 Aug 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
