2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-7.0 » linux32 #61
To: [email protected]
Date: Tue, 11 Sep 2018 09:44:21 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux32/61/display/redirect>
Started by upstream project "epics-7.0" build number 61
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on linux32-uranus (linux32) in workspace <https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux32/ws/>
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base/
 > git init <https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux32/ws/> # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
 > git --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*
ERROR: Timeout after 10 minutes
ERROR: Error cloning remote repo 'origin'
hudson.plugins.git.GitException: Command "git fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*" returned status code 143:
stdout:
stderr: error: RPC failed; result=52, HTTP code = 100
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2016)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1735)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:72)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:420)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$2.execute(CliGitAPIImpl.java:629)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
	at hudson.remoting.UserRequest.perform(UserRequest.java:212)
	at hudson.remoting.UserRequest.perform(UserRequest.java:54)
	at hudson.remoting.Request$2.run(Request.java:369)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
	at java.lang.Thread.run(Thread.java:748)
	Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to linux32-uranus
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
		at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
		at hudson.remoting.Channel.call(Channel.java:955)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
		at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
		at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
		at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
		at java.lang.reflect.Method.invoke(Method.java:498)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
		at com.sun.proxy.$Proxy118.execute(Unknown Source)
		at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1146)
		at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1186)
		at hudson.scm.SCM.checkout(SCM.java:504)
		at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
		at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
		at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
		at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
		at hudson.model.Run.execute(Run.java:1798)
		at hudson.matrix.MatrixRun.run(MatrixRun.java:153)
		at hudson.model.ResourceController.execute(ResourceController.java:97)
		at hudson.model.Executor.run(Executor.java:429)
[WARNINGS] Skipping publisher since build result is FAILURE
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.*/*.tap
Did not find any matching files.
Jenkins build is unstable: epics-7.0 » linux32 #62 APS Jenkins
Prev: Re: Perl scripts: eval exec instead of shebang - why? Andrew Johnson
Next: Perl scripts shebang: /usr/bin/perl vs. /usr/bin/env perl J. Lewis Muir
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Jenkins build is unstable: epics-7.0 » linux32 #62 APS Jenkins
ANJ, 17 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
