2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Perl scripts shebang: /usr/bin/perl vs. /usr/bin/env perl
To: [email protected]
Date: Tue, 11 Sep 2018 11:55:45 -0500
Hi, all!
I suggest that all EPICS-Base-installed Perl scripts should use an
absolute path to the desired Perl interpreter in their shebang line
rather than using env to invoke the interpreter.
I'm reminded of this because of
  https://epics.anl.gov/core-talk/2018/msg00443.php
in which Martin Konrad wrote:
> Looking at the Perl scripts included in EPICS Base I'm wondering if it
> is really necessary to start some of them (see for example [1]) with the
> rather esoteric
> eval 'exec perl -S $0 ${1+"$@"}'  # -*- Mode: perl -*-
>     if $running_under_some_shell;
> rather than the usual "#!/usr/bin/perl" or "#!/usr/bin/env perl"
I would much prefer the former over the latter, but it seems the latter
is what has been chosen!  This was discussed on Tech-Talk in
  https://epics.anl.gov/tech-talk/2013/msg00098.php
but I'll just say again, I think the pathname of the Perl interpreter
should be specified as a variable in an appropriate file under configure
and for that to be used in the shebang line of all installed Perl
scripts.  I would like scripts to work without requiring perl to be
on the command search path, and I would like to be able to specify
which perl is used for the scripts when they are installed rather than
whatever perl is first on the command search path.  This way, the
scripts do not rely on the command search path to find perl, and if
multiple versions of Perl are installed, or if the perl that is first
on the command search path changes, I can be sure that the installed
scripts will continue to work.  For more on this opinion, see
  http://julio.meroh.net/2016/09/env-considered-harmful.html
Thanks!
Lewis
Re: Perl scripts shebang: /usr/bin/perl vs. /usr/bin/env perl J. Lewis Muir
Re: Perl scripts shebang: /usr/bin/perl vs. /usr/bin/env perl Benjamin Franksen
Prev: Build failed in Jenkins: epics-7.0 » linux32 #61 APS Jenkins
Next: Re: Perl scripts shebang: /usr/bin/perl vs. /usr/bin/env perl Konrad, Martin
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to stable : epics-7.0 » linux32 #63 APS Jenkins
Next: Re: Perl scripts shebang: /usr/bin/perl vs. /usr/bin/env perl J. Lewis Muir
ANJ, 05 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
