Subject: |
Re: Perl scripts shebang: /usr/bin/perl vs. /usr/bin/env perl |
"J. Lewis Muir" <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 5 Nov 2018 09:48:13 -0600 |
On 09/11, J. Lewis Muir wrote:
> Hi, all!
> I suggest that all EPICS-Base-installed Perl scripts should use an
> absolute path to the desired Perl interpreter in their shebang line
> rather than using env to invoke the interpreter.
> I'm reminded of this because of
> https://epics.anl.gov/core-talk/2018/msg00443.php
> in which Martin Konrad wrote:
> > Looking at the Perl scripts included in EPICS Base I'm wondering if it
> > is really necessary to start some of them (see for example [1]) with the
> > rather esoteric
> > eval 'exec perl -S $0 ${1+"$@"}' # -*- Mode: perl -*-
> > if $running_under_some_shell;
> > rather than the usual "#!/usr/bin/perl" or "#!/usr/bin/env perl"
> I would much prefer the former over the latter, but it seems the latter
> is what has been chosen! This was discussed on Tech-Talk in
> https://epics.anl.gov/tech-talk/2013/msg00098.php
> but I'll just say again, I think the pathname of the Perl interpreter
> should be specified as a variable in an appropriate file under configure
> and for that to be used in the shebang line of all installed Perl
> scripts. I would like scripts to work without requiring perl to be
> on the command search path, and I would like to be able to specify
> which perl is used for the scripts when they are installed rather than
> whatever perl is first on the command search path. This way, the
> scripts do not rely on the command search path to find perl, and if
> multiple versions of Perl are installed, or if the perl that is first
> on the command search path changes, I can be sure that the installed
> scripts will continue to work. For more on this opinion, see
> http://julio.meroh.net/2016/09/env-considered-harmful.html
> Thanks!
> Lewis
Hello!
Would any core developers be willing to weigh in on this?
Here's the archive of the thread in case you no longer have it:
https://epics.anl.gov/core-talk/2018/msg00448.php
The only core developer who replied to this thread was Michael
Davidsaver, but that was not about this, it was about a thread hijack on
bashisms.
Thanks!
Lewis
- Re: Perl scripts shebang: /usr/bin/perl vs. /usr/bin/env perl Michael Davidsaver
- Re: Perl scripts shebang: /usr/bin/perl vs. /usr/bin/env perl Johnson, Andrew N. via Core-talk
- Perl scripts shebang: /usr/bin/perl vs. /usr/bin/env perl J. Lewis Muir
RTEMS5 with epics-base Heinz Junkes
<2018>
2025
2026
<2018>
2025
2026
