2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RTEMS5 with epics-base
To: EPICS Core Talk <[email protected]>, Heinz Junkes <[email protected]>
Date: Sat, 3 Nov 2018 12:12:26 +0100
Hello friends,
unfortunately, it's only now that I get back to taking care of rtems-5 for epics-base.
And unfortunately, I haven't really taken care of travis-ci yet. I found the last "travis-run” for rtems 4.10:
https://travis-ci.org/epics-base/epics-base/jobs/450069785.
I'm going to try to replay this on my computer first.
Do I see it right that I should then try to do exactly that with rtems-5. So on the qemu-system-x86 with the rtems i386 bsp?
The next step would then be on my hardware mvme6100? And maybe also on the qemu for mvme3100?
@Michael: Can you write me again where I can get the qemu mvme3100 from?
I'll try my luck and hope to make it to Melbourne.
Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: RTEMS5 with epics-base Heinz P. Junkes
Prev: Re: hanging test in 3.15 Johnson, Andrew N. via Core-talk
Next: Re: Perl scripts shebang: /usr/bin/perl vs. /usr/bin/env perl J. Lewis Muir
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Problem with cross-tests Dirk Zimoch
Next: Re: RTEMS5 with epics-base Heinz P. Junkes
ANJ, 08 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
