On 09/17/2018 02:11 PM, Andrew Johnson wrote:
> On 09/17/2018 04:04 PM, APS Jenkins wrote:
>> See <https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux32/62/display/redirect>
> This was a pva2pva test failure:
I've seen this a couple of times now. I think it's false positive from a race in the test code.
Not a high priority for me at present.
>> testweak.tap ......... ok
>> testtest.tap ......... ok
>> testpvif.tap ......... ok
>> testpdb.tap .......... ok
>> testpvalink.tap ......
>> not ok 9 - dbGetField("src:li1.VAL", 5) -> 4 == 42
>> Failed 1/15 subtests
>> testgroupconfig.tap .. ok
>> testdbf_copy.tap ..... ok
>> Test Summary Report
>> testpvalink.tap (Wstat: 0 Tests: 15 Failed: 1)
>> Failed test: 9
>> Files=7, Tests=323, 1 wallclock secs ( 0.15 usr 0.04 sys + 0.00 cusr 0.02 csys = 0.21 CPU)
>> Result: FAIL
> - Andrew
- Re: Jenkins build is unstable: epics-7.0 » linux32 #62 Johnson, Andrew N.
- Build failed in Jenkins: epics-7.0 » linux32 #61 APS Jenkins
- Jenkins build is unstable: epics-7.0 » linux32 #62 APS Jenkins
- Re: Jenkins build is unstable: epics-7.0 » linux32 #62 Andrew Johnson
Jenkins build is back to normal : epics-base-3.15-ios #195 APS Jenkins
<2018>
2025
2026
<2018>
2025
2026
