2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Make problem in EPICS 7
To: EPICS Core Talk <[email protected]>
Date: Tue, 25 Sep 2018 13:35:46 +0200
There is a problem with access rights in pvAccess/testCa when re-building EPICS.
make[4]: Entering directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0/modules/pvAccess/testCa/O.RHEL7-x86_64'
cp /usr/local/epics/base-7.0.1/dbd/softIoc.dbd ../O.Common/testIoc.dbd
cp: cannot create regular file ‘../O.Common/testIoc.dbd’: Permission denied
make[4]: *** No rule to make target `../O.Common/testIoc.dbd', needed by `testIoc_registerRecordDeviceDriver.cpp'. Stop.
If testIoc.dbd already exists from the last build, it has no write access:
-r--r--r-- 1 zimoch sls 433697 Sep 25 13:31 modules/pvAccess/testCa/O.Common/testIoc.dbd
Thus copying the new version from $(EPICS_BASE)/dbd/softIoc.dbd fails. Need to copy with -f or simply delete the old file first.
The rule in modules/pvAccess/testCa/Makefile is:
ifdef BASE_3_16
  $(COMMON_DIR)/testIoc.dbd: $(EPICS_BASE)/dbd/softIoc.dbd
        $(CP) $< $@
endif
but should be:
ifdef BASE_3_16
        $(RM) $@
        $(CP) $< $@
endif
Patch attached.
Dirk
diff --git a/testCa/Makefile b/testCa/Makefile
index 9cfe317..47092ac 100644
--- a/testCa/Makefile
+++ b/testCa/Makefile
@@ -43,5 +43,6 @@ include $(TOP)/configure/RULES
 ifdef BASE_3_16
+	$(RM) $@
 	$(CP) $< $@
 endif
Prev: RE: Bug in mbbo and mbbi records in Base 7.0 Mark Rivers
Next: Re: [CloudBees Support] Re: Jenkins stuck in non-restartable state Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 25 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
