2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Bug in mbbo and mbbi records in Base 7.0
To: "'Johnson, Andrew N.'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 24 Sep 2018 23:52:17 +0000
I have tested the patch and it fixes the problem.
Thanks for the quick response!
-----Original Message-----
From: [email protected] <[email protected]> On Behalf Of Johnson, Andrew N.
Sent: Monday, September 24, 2018 6:07 PM
To: [email protected]
Subject: Re: Bug in mbbo and mbbi records in Base 7.0
Hi Mark,
On 09/24/2018 05:59 PM, Mark Rivers wrote:
> Just a heads up that I found there is a bug in the mbbo and mbbi
> records in 7.0 today.  The problem is that one cannot modify the ZRVL
> through FFVL fields at run-time, which is a problem on our beamlines.
> Andrew found the problem in the special() functions in these records
> and should have a patch soon.
I filed this bug in Launchpad:
  https://bugs.launchpad.net/epics-base/+bug/1794196
The git patch is attached ("git apply filename.patch" should work), please test and let me know the results.
- Andrew
Arguing for surveillance because you have nothing to hide is no different than making the claim, "I don't care about freedom of speech because I have nothing to say." -- Edward Snowdon
Bug in mbbo and mbbi records in Base 7.0 Mark Rivers
Re: Bug in mbbo and mbbi records in Base 7.0 Johnson, Andrew N.
Prev: Re: Bug in mbbo and mbbi records in Base 7.0 Johnson, Andrew N.
Next: Make problem in EPICS 7 Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 25 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
