2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: compiler problem in pvData/testApp
To: [email protected]
Date: Thu, 27 Sep 2018 06:23:45 -0400
On 09/27/2018 03:52 AM, Dirk Zimoch wrote:
BTW: This leads to the question: If we have separate modules, why do they all install their headers to the same directory "pv" instead of one directory for each module?
I will make the change in pvDatabasCPP and see if it fixes the problem.
Marty
On 27.09.2018 09:41, Dirk Zimoch wrote:
Indeed, there are two pvCopy.h, pvData/src/copy/pv/pvCopy.h and pvDatabase/src/copy/pv/pvCopy.h but both get installed to $(INSTALL_LOCATION)/include/pv/pvCopy.h. Thus one overwrites the other.
For the moment, I skip pvDatabase. That at least allows to compile again the rest of EPICS 7.
Dirk
On 26.09.2018 19:01, Johnson, Andrew N. wrote:
I'm pretty sure this was caused by Marty's adding the pvCopy code to
pvDatabaseCPP, which includes a similar to but not identical header as
the one that is still in pvDataCPP and presumably being used by the
testApp/copy/testPVCopy.cpp source that is also still in pvData.
I don't have time right now to work out what needs to be removed, Marty
could you generate a PR to remove pvCopy and the associated test
program(s) from pvData? I think that's what we need to do to fix this.
- Andrew
On 09/26/2018 10:39 AM, Dirk Zimoch wrote:
Hello,
Since last weekend building EPICS 7 fails in pvData/testApp.
Can please someone fix this or at least tell me which commit to check
out so that I can compile again? Unfortunately I failed to find out what
exactly the problem is or which old commit to check out to make it
compile again.
make[4]: Entering directory
`/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0/modules/pvData/testApp/O.RHEL7-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_
-DUNIX  -Dlinux     -O3   -Wall           -m64  -I. -I../O.Common -I.
-I. -I.. -I../../testApp/misc -I../../testApp/pv
-I../../testApp/property -I../../testApp/copy
-I/usr/local/epics/base-7.0.1/include/compiler/gcc
-I/usr/local/epics/base-7.0.1/include/os/Linux
-I/usr/local/epics/base-7.0.1/include        -c
../../testApp/copy/testPVCopy.cpp
../../testApp/copy/testPVCopy.cpp:38:5: error: ‘PVCopyPtr’ has not been
declared
      PVCopyPtr const & pvCopy)
../../testApp/copy/testPVCopy.cpp: In function ‘void testPVScalar(const
string&, const string&, const PVStructurePtr&, const int&)’:
../../testApp/copy/testPVCopy.cpp:48:41: error: base operand of ‘->’ is
not a pointer
      StructureConstPtr structure = pvCopy->getStructure();
../../testApp/copy/testPVCopy.cpp:49:29: error: base operand of ‘->’ is
not a pointer
      pvStructureCopy = pvCopy->createPVStructure();
../../testApp/copy/testPVCopy.cpp:52:11: error: base operand of ‘->’ is
not a pointer
      pvCopy->initCopy(pvStructureCopy, bitSet);
../../testApp/copy/testPVCopy.cpp:56:11: error: base operand of ‘->’ is
not a pointer
pvCopy->updateCopySetBitSet(pvStructureCopy,bitSet);
../../testApp/copy/testPVCopy.cpp:60:11: error: base operand of ‘->’ is
not a pointer
      pvCopy->getCopyOffset(pvValueMaster);
../../testApp/copy/testPVCopy.cpp:67:11: error: base operand of ‘->’ is
not a pointer
pvCopy->updateCopyFromBitSet(pvStructureCopy,bitSet);
../../testApp/copy/testPVCopy.cpp:74:11: error: base operand of ‘->’ is
not a pointer
      pvCopy->updateMaster(pvStructureCopy,bitSet);
../../testApp/copy/testPVCopy.cpp: At global scope:
../../testApp/copy/testPVCopy.cpp:83:5: error: ‘PVCopyPtr’ has not been
declared
testPVScalarArray(const string&, const string&, const PVStructurePtr&,
const int&)’:
../../testApp/copy/testPVCopy.cpp:97:41: error: base operand of ‘->’ is
not a pointer
../../testApp/copy/testPVCopy.cpp:99:29: error: base operand of ‘->’ is
not a pointer
../../testApp/copy/testPVCopy.cpp:102:11: error: base operand of ‘->’ is
not a pointer
../../testApp/copy/testPVCopy.cpp:110:11: error: base operand of ‘->’ is
not a pointer
../../testApp/copy/testPVCopy.cpp:114:11: error: base operand of ‘->’ is
not a pointer
../../testApp/copy/testPVCopy.cpp:125:11: error: base operand of ‘->’ is
not a pointer
../../testApp/copy/testPVCopy.cpp:137:11: error: base operand of ‘->’ is
not a pointer
../../testApp/copy/testPVCopy.cpp: In function ‘void scalarTest()’:
../../testApp/copy/testPVCopy.cpp:149:5: error: ‘PVCopyPtr’ was not
declared in this scope
      PVCopyPtr pvCopy;
../../testApp/copy/testPVCopy.cpp:149:5: note: suggested alternative:
In file included from ../../testApp/copy/testPVCopy.cpp:26:0:
/usr/local/epics/base-7.0.1/include/pv/pvCopy.h:45:38: note:
‘epics::pvDatabase::PVCopyPtr’
  typedef std::tr1::shared_ptr<PVCopy> PVCopyPtr;
../../testApp/copy/testPVCopy.cpp:149:15: error: expected ‘;’ before
‘pvCopy’
      PVCopyPtr pvCopy;
../../testApp/copy/testPVCopy.cpp:159:5: error: ‘pvCopy’ was not
      pvCopy = PVCopy::create(pvMaster,pvRequest,"");
../../testApp/copy/testPVCopy.cpp:159:14: error: ‘PVCopy’ has not been
declared
../../testApp/copy/testPVCopy.cpp:166:14: error: ‘PVCopy’ has not been
declared
../../testApp/copy/testPVCopy.cpp:173:14: error: ‘PVCopy’ has not been
declared
../../testApp/copy/testPVCopy.cpp: In function ‘void arrayTest()’:
../../testApp/copy/testPVCopy.cpp:186:5: error: ‘PVCopyPtr’ was not
      PVCopyPtr pvCopy;
../../testApp/copy/testPVCopy.cpp:186:5: note: suggested alternative:
../../testApp/copy/testPVCopy.cpp:186:15: error: expected ‘;’ before
‘pvCopy’
      PVCopyPtr pvCopy;
../../testApp/copy/testPVCopy.cpp:196:5: error: ‘pvCopy’ was not
../../testApp/copy/testPVCopy.cpp:196:14: error: ‘PVCopy’ has not been
declared
../../testApp/copy/testPVCopy.cpp:203:14: error: ‘PVCopy’ has not been
declared
../../testApp/copy/testPVCopy.cpp:210:14: error: ‘PVCopy’ has not been
declared
../../testApp/copy/testPVCopy.cpp: In function ‘void powerSupplyTest()’:
../../testApp/copy/testPVCopy.cpp:251:5: error: ‘PVCopyPtr’ was not
      PVCopyPtr pvCopy;
../../testApp/copy/testPVCopy.cpp:251:5: note: suggested alternative:
../../testApp/copy/testPVCopy.cpp:251:15: error: expected ‘;’ before
‘pvCopy’
      PVCopyPtr pvCopy;
../../testApp/copy/testPVCopy.cpp:261:5: error: ‘pvCopy’ was not
../../testApp/copy/testPVCopy.cpp:261:14: error: ‘PVCopy’ has not been
declared
../../testApp/copy/testPVCopy.cpp:268:14: error: ‘PVCopy’ has not been
declared
../../testApp/copy/testPVCopy.cpp:275:14: error: ‘PVCopy’ has not been
declared
../../testApp/copy/testPVCopy.cpp:282:14: error: ‘PVCopy’ has not been
declared
make[4]: *** [testPVCopy.o] Error 1
make[4]: Leaving directory
In case it matters: I have this problem with several gcc versions, e.g
4.8.5 and 6.2.1. Also with clang, but with better error message:
../../testApp/copy/testPVCopy.cpp:38:5: error: unknown type name
'PVCopyPtr'; did you mean 'epics::pvDatabase::PVCopyPtr'?
Thus the problem seems to be namespace related. However I could not find out how to fix it. Using namespace epics::pvDatabase only seems to make
things worse.
Dirk
compiler problem in pvData/testApp Dirk Zimoch
Re: compiler problem in pvData/testApp Johnson, Andrew N.
Re: compiler problem in pvData/testApp Dirk Zimoch
Prev: Re: compiler problem in pvData/testApp Dirk Zimoch
Next: Re: compiler problem in pvData/testApp Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 27 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
