2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: compiler problem in pvData/testApp
To: [email protected]
Date: Thu, 27 Sep 2018 15:29:56 -0400
On 09/27/2018 07:18 AM, Ralph Lange wrote:
On Thu, 27 Sep 2018 at 09:53, Dirk Zimoch <[email protected]> wrote:
BTW: This leads to the question: If we have separate modules, why do
they all install their headers to the same directory "pv" instead of one
directory for each module?
Because they are parts of the same bundle of software (the V4 parts we just recently decided to call "PVA").
The members pvData, pvAccess, pvDatabase, pvClient, pvNT, ... are closely related, released as a bundle and share the same prefix "pv", which was selected to determine the name for the include subdirectory.
Cheers,
~Ralph
So then what should be done?
What I have been doing is two things:
1) All the copy modules will be accessed via include/pvcopy/*
2) All the copy code is in namespace epics::pvCopy
I have it working but exampleCPP/exampleLink fails.
I found the problem is that
#include <pv/pvCopy.h>
appeared in pvaClent.h and in exampleLink.
When I removed them all build.
I have to do more more testing before I create a pull request for all of pvaClientCPP exampleCPP and pvDatabaseCPP.
But what do I do about Ralph's comment above?
Marty
Re: compiler problem in pvData/testApp Johnson, Andrew N.
compiler problem in pvData/testApp Dirk Zimoch
Re: compiler problem in pvData/testApp Dirk Zimoch
Re: compiler problem in pvData/testApp Ralph Lange
Prev: Re: compiler problem in pvData/testApp Ralph Lange
Next: Re: compiler problem in pvData/testApp Johnson, Andrew N.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 27 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
