2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A question for the git experts
To: Ralph Lange <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Mon, 1 Oct 2018 09:44:14 +0200
On 28.09.2018 20:07, Ralph Lange wrote:
Isn't that what we do large style in base by calling all local configuration files *.local and excluding them from SCM via .gitignore?
But I want to track them in my git repo of course.
You could also try to play with different .gitignore files in different branches to have the local files under version control in "your" branches.
But then I have the same problem with the different versions of .gitignore. Merging would overwrite with my local .gitignore. Right? Also I found that git ignores the .gitignore patterns for files that are already in git. Thus I think it will not help.
Dirk
Cheers,
~Ralph
On Fri, 28 Sep 2018 at 12:16, Dirk Zimoch <[email protected] <mailto:[email protected]>> wrote:
    Hi folks,
    I have a question about the preferred work flow with git when having
    "private" files.
    In order to compile for all our architectures, I have many CONFIG files
    that are PSI specific. So I keep them on my "PSI-7.0" branch, which is
    based in the "7.0" branch. Whenever there are changes in the "7.0"
    branch, I merge them in. No problem.
    When I develop something, I need my CONFIG files of course to actually
    compile anything. Thus I need to work on the "PSI-7.0" branch or better
    on a feature branch based in "PSI-7.0".
    Now the problem starts: When merging the feature back, I do not want to
    pollute the "7.0" branch with my CONFIG* files.
    So how to do this? How to tell git "during a merge, ignore those files"?
    My workaround so far: I develop on the "PSI-7.0" branch but never
    commit. Instead I stash the changes, then check out the feature branch
    which is based in "7.0" and apply the stash. Then I can commit and push.
    The disadvantage is that I have to delay the commit to a time when I
    have already forgotten what the idea was. Also I may have other local
    changes which should not go into the feature branch, but stash copies
    them all.
    Is there a better way to do this?
    Dirk
Re: A question for the git experts Hill, Bruce
A question for the git experts Dirk Zimoch
Re: A question for the git experts Ralph Lange
Prev: Build failed in Jenkins: EPICS-7 #114 Jenkins Epics PSI
Next: Re: A question for the git experts Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: A question for the git experts Ralph Lange
Next: Re: A question for the git experts Hill, Bruce
ANJ, 02 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
