2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: A question for the git experts
To: Dirk Zimoch <[email protected]>, core-talk <[email protected]>
Date: Tue, 2 Oct 2018 10:51:03 -0700
Dirk,
Have you found "git rebase -i <rev>"?  This allows interactive
(via a text editor) operations on <rev>..HEAD .  I use this on
a daily basis to juggle patch sets to move revisions I don't
want to push after those which I do.
I also occasionally move patch stacks between branches with
> git rebase --onto <new_base> <rev_from> <branch>
This moves <rev_from>...<branch> onto <new_base> and then
checks out <branch> at it's new location.
I imagine there are equivalents with "git cherry-pick", so my
preference may be historical at this point.
On 10/2/18 12:08 AM, Dirk Zimoch wrote:
> The cherry-pick method works well, including the ranged version.
> I use gitk as a graphical fronted, but that does not support multiple cherry-picks at once. Still works reasonably well.
> Thanks everyone.
> Dirk
> On 01.10.2018 11:51, Niklas Claesson wrote:
>> Hi Dirk,
>> With modern git versions (>1.7.2) you can do `git cherry-pick A..B`, where A would be the hash of the initial commit you want and B can be a commit hash or branch name.
>> Here are some convenient aliases to look at the git history in the terminal instead of using guis:
>> [alias]
>> l = log --graph --pretty=format:'%C(yellow)%h%Creset%C(blue)%d%Creset %C(white bold)%s%Creset %C(white dim)(by %an %ar)%Creset'
>> ll = !git l --all
>> Cheers
>> ----- On 1 Oct, 2018, at 09:47, Dirk Zimoch <[email protected]> wrote:
>>     On 28.09.2018 16:31, Konrad, Martin wrote:
>>      > Hi Dirk,
>>      >> Is there a better way to do this?
>>      > Always merge from "upstream" to "PSI-7.0"
>>     Yes, that part works.
>>      > never the other way around.
>>      > Develop on your "PSI-7.0" branch and then "git cherry-pick" the
>>     commits
>>      > you consider generic enough to "upstream". This shouldn't result in
>>      > merge conflicts when you merge from "upstream" to "PSI-7.0" in
>>     the future.
>>      > -Martin
>>     There is no way to automatically cherry-pick all the changes after a
>>     given commit, is there?
>> Niklas Claesson, HW & SW Developer        Cosylab Switzerland
>> M.S., Electrical Engineering           http://www.cosylab.com
>>   Email: [email protected]
>>   Phone: +41 765 491901
>> Google: [email protected]
>>   Skype: nickez
Re: A question for the git experts Konrad, Martin
Re: A question for the git experts Dirk Zimoch
Re: A question for the git experts Niklas Claesson
Prev: Build failed in Jenkins: EPICS-3.14 #119 Jenkins Epics PSI
Next: Build failed in Jenkins: EPICS-7 #117 Jenkins Epics PSI
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: A question for the git experts Dirk Zimoch
Next: Build failed in Jenkins: EPICS-7 #116 Jenkins Epics PSI
ANJ, 02 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
