Subject: |
Is breaking strict-aliasing rules something to worry about? |
Dirk Zimoch <[email protected]> |
To: |
EPICS Core Talk <[email protected]> |
Date: |
Wed, 3 Oct 2018 16:12:24 +0200 |
I had removed all the -fno-strict-aliasing flags from my configurations
because I thought it was not necessary any more with EPICS 7, but the
warnings are back:
/usr/local/epics/base-7.0.1/include/pv/anyscalar.h:111: warning:
dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
As I understand, strict aliasing rules allow the compiler to do some
aggressive optimization by assuming an assignment to a pointer of type
A* can never change a variable of type B, given A and B are sufficiently
different types. Thus a variable of type B can be safely kept in a
register and does not need to be reloaded from memory only because a
pointer of type A* has been written to.
The option -fno-strict-aliasing switches off that optimization and thus
the warning as well.
But I don't know if the warning means that the optimizer will not touch
the expressions that break strict-aliasing rules or if the optimizer
will do its work anyway, potentially leading to very subtle and hard to
debug run-time errors.
I propose to either
a) Fix the code and be careful to never break strict-aliasing rules, i.e
fix it immediately when such warnings pop up.
b) Use -fno-strict-aliasing for all compilers that support it (gcc 3+ ?)
Dirk
- Re: Is breaking strict-aliasing rules something to worry about? Michael Davidsaver
Re: Something wrong with the repo? Konrad, Martin
Re: Something wrong with the repo? Dirk Zimoch
<2018>
2025
2026
Re: Something wrong with the repo? Johnson, Andrew N.
<2018>
2025
2026
ANJ, 03 Oct 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
