2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS_IOC_LOG_PORT value
To: [email protected]
Date: Fri, 5 Oct 2018 00:35:47 +0200
Hi Andrew,
The value 7004 given in configure/CONFIG_ENV is the default value which
gets compiled into libCom.
  Yes, I saw it.
[1] configure/CONFIG_ENV
[2] modules/libcom/src/log/S99logServer@
The S99logServer@ file is a template for a System-V init script that
sites can use to start a log server. When Base gets built the
@INSTALL_BIN@ macro in that template is replaced with the path to the
Base installation, and the result is installed into the bin/<host>
directory as S99logServer. To use this script though the user would
still have to copy the S99.. file into an appropriate directory under
/etc/init.d on the machine that will run the log server, and they should
also make any changes to the other variables in that file as needed by
their installation (usually the EPICS_IOC_LOG_FILE_NAME variable at least).
The commented-out value 6500 that appears for EPICS_IOC_LOG_PORT in the
script is to show that you can override the compiled-in default port
number if you want/need to. Here at the APS we used to run 3 or 4 log
servers, with IOCs from different parts of the machine logging to
different ports (on the same host) and hence to different log-files.
Before jumping into the caPutLog, I would like to see the logserver running in my local PC. And I've overridden its default value within each ioc startup script in order to match the port of a logServer. However, at the first attempt, my assumption when I modified S99logServer.sh in order to use it as a stand-alone script is that 6045 is the EPICS base default value. However, it took a while to figure out that the default value is 7004.
And my question is very silly, because I have to understand how it works within all EPICS application. I had a silly thought, if the value is the same 7004, it may give me a small success without searching where the default value is. That may give similar small success for future learners (like me), who would like to learn EPICS without understanding them deeply.
Nowadays it is not necessary to use our log server, and I suggest that
sites use a plugin for one of the many common logging servers now
available such as logstash instead. When enabled the IOC's log client
just opens a TCP socket to the host and sends plain text messages, so
most tcp input plugins will work fine instead.
If a site has strong and quick IT supports in any forms, it is no problem to use modernized and fancy log servers, such as logstash, fluentd, and so on. However, there is no support given in any forms, I am sure, logServer is still a good tool. For me, it is the very useful one, because I can test see ioc logs in a logserver without any more application configuration and installation. The iocLogServer is the good enough for me.
I can provide a configuration file for logstash that I have experimented
with to anyone who wants it, but I'm sure that most other log servers
would be able to do the same thing.
I would like to receive your configuration file for logstash. I hope I can get some supports in near future.
  Thank you for your support.
  Best,
  Han
Re: EPICS_IOC_LOG_PORT value Heinz Junkes
EPICS_IOC_LOG_PORT value Jeong Han Lee
Re: EPICS_IOC_LOG_PORT value Johnson, Andrew N.
Prev: Re: EPICS_IOC_LOG_PORT value Johnson, Andrew N.
Next: Re: Is breaking strict-aliasing rules something to worry about? Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS_IOC_LOG_PORT value Heinz Junkes
ANJ, 09 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
