2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS make runtests fails
To: EPICS Core Talk <[email protected]>
Date: Tue, 16 Oct 2018 17:51:15 +0200
Hi folks,
When doing 'make runtests' for EPICS 3.15, I get:
make[3]: Entering directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-3.15/src/tools/test/O.linux-x86' perl -CSD -MTest::Harness -e 'runtests @ARGV if @ARGV;' Breaktable.t DBD.t Device.t Driver.t Function.t macLib.t Menu.t Recfield.t Recordtype.t Registrar.t Snippets.t Variable.t Can't locate Test/More.pm in @INC (@INC contains: ../.. /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at Breaktable.t line 5.
BEGIN failed--compilation aborted at Breaktable.t line 5.
Breaktable.t ..
Dubious, test returned 2 (wstat 512, 0x200)
No subtests run
It seems the file "Test/More.pm" is missing.
Similar thing with 3.16:
make[3]: Entering directory `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-3.16/src/tools/test/O.linux-x86' perl -CSD -MTest::Harness -e 'runtests @ARGV if @ARGV;' Base.t Breaktable.t DBD.t Device.t Driver.t Function.t macLib.t Menu.t Recfield.t Recordtype.t Registrar.t Snippets.t Variable.t Can't locate Test/More.pm in @INC (@INC contains: ../.. /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at Base.t line 5.
Dirk
Re: EPICS make runtests fails Johnson, Andrew N.
Prev: Build failed in Jenkins: EPICS-3.15 #127 Jenkins EPICS PSI
Next: Build failed in Jenkins: EPICS-3.15 #128 Jenkins EPICS PSI
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : EPICS-3.15 #134 Jenkins EPICS PSI
Next: Re: EPICS make runtests fails Johnson, Andrew N.
ANJ, 17 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
