2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS make runtests fails
Date: Tue, 16 Oct 2018 16:07:18 +0000
Hi Dirk,
On 10/16/2018 10:51 AM, Dirk Zimoch wrote:
> make[3]: Entering directory
> `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-3.15/src/tools/test/O.linux-x86'
> perl -CSD -MTest::Harness -e 'runtests @ARGV if @ARGV;' Breaktable.t
> DBD.t Device.t Driver.t Function.t macLib.t Menu.t Recfield.t
> Recordtype.t Registrar.t Snippets.t Variable.t
> Can't locate Test/More.pm in @INC (@INC contains: ../..
> /usr/local/lib64/perl5 /usr/local/share/perl5
> /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl
> /usr/lib64/perl5 /usr/share/perl5 .) at Breaktable.t line 5.
> BEGIN failed--compilation aborted at Breaktable.t line 5.
> Breaktable.t ..
> Dubious, test returned 2 (wstat 512, 0x200)
> No subtests run
> It seems the file "Test/More.pm" is missing.
Test::More is a Perl module that used to be included in all Perl
installations. On my RHEL7 system it is in the RPM
    perl-Test-Simple-0.98-243.el7.noarch
We have been using this module in 3.15's src/tools/test programs since
before 3.15.0 came out, so if you used to be able to build the 3.15
branch something has changed on your system; maybe a new installation of
Perl on /usr/local needs to have that module adding?
- Andrew
Re: EPICS make runtests fails Dirk Zimoch
Prev: Build failed in Jenkins: EPICS-3.15 #128 Jenkins EPICS PSI
Next: Build failed in Jenkins: EPICS-3.15 #129 Jenkins EPICS PSI
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: EPICS make runtests fails Dirk Zimoch
Next: Re: EPICS make runtests fails Dirk Zimoch
ANJ, 17 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
