It seems the file "Test/More.pm" is missing.
Test::More is a Perl module that used to be included in all Perl
installations. On my RHEL7 system it is in the RPM
perl-Test-Simple-0.98-243.el7.noarch
We have been using this module in 3.15's src/tools/test programs since
before 3.15.0 came out, so if you used to be able to build the 3.15
branch something has changed on your system; maybe a new installation of
Perl on /usr/local needs to have that module adding?
- Andrew
Hi Andrew,
Thanks for the hint. I will have a look at our Perl installation. I
thought the file was meant to be part of EPICS.
Dirk
- EPICS make runtests fails Dirk Zimoch
- Re: EPICS make runtests fails Johnson, Andrew N.
Build failed in Jenkins: EPICS-7 #126 Jenkins EPICS PSI
Build failed in Jenkins: EPICS-3.15 #131 Jenkins EPICS PSI
<2018>
2025
2026
Build failed in Jenkins: EPICS-3.16 #126 Jenkins EPICS PSI
<2018>
2025
2026
ANJ, 17 Oct 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
