2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-7 #126
To: <[email protected]>, <[email protected]>
Date: Tue, 16 Oct 2018 20:35:43 +0200
See <http://gfa-sls2-test:8080/job/EPICS-7/126/display/redirect>
[...truncated 3.89 MB...]
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE        -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsReadline.d  ../../src/osi/epicsReadline.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF osdEnv.d  ../../src/osi/os/default/osdEnv.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF osdSignal.d  ../../src/osi/os/posix/osdSignal.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF osdPoolStatus.d  ../../src/osi/os/default/osdPoolStatus.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF osdInterrupt.d  ../../src/osi/os/default/osdInterrupt.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF osdFindSymbol.d  ../../src/osi/os/posix/osdFindSymbol.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF osdAssert.d  ../../src/osi/os/default/osdAssert.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsSocketConvertErrnoToString.d  ../../src/osi/os/default/epicsSocketConvertErrnoToString.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF systemCallIntMech.d  ../../src/osi/os/posix/systemCallIntMech.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF osiSock.d  ../../src/osi/osiSock.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF osdSockAddrReuse.d  ../../src/osi/os/posix/osdSockAddrReuse.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF osdSock.d  ../../src/osi/os/posix/osdSock.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF osiClockTime.d  ../../src/osi/osiClockTime.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsGeneralTime.d  ../../src/osi/epicsGeneralTime.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsAtomicOSD.d  ../../src/osi/os/posix/epicsAtomicOSD.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsMath.d  ../../src/osi/epicsMath.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsMessageQueue.d  ../../src/osi/epicsMessageQueue.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsTime.d  ../../src/osi/epicsTime.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsEvent.d  ../../src/osi/epicsEvent.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsMutex.d  ../../src/osi/epicsMutex.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsThread.d  ../../src/osi/epicsThread.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsUnitTest.d  ../../src/misc/epicsUnitTest.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF ipAddrToAsciiAsynchronous.d  ../../src/misc/ipAddrToAsciiAsynchronous.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF truncateFile.d  ../../src/misc/truncateFile.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsString.d  ../../src/misc/epicsString.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsStdlib.d  ../../src/misc/epicsStdlib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsExit.d  ../../src/misc/epicsExit.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsConvert.d  ../../src/misc/epicsConvert.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF cantProceed.d  ../../src/misc/cantProceed.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF adjustment.d  ../../src/misc/adjustment.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF aToIPAddr.d  ../../src/misc/aToIPAddr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF alarmString.d  ../../src/misc/alarmString.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF macUtil.d  ../../src/macLib/macUtil.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF macEnv.d  ../../src/macLib/macEnv.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF macCore.d  ../../src/macLib/macCore.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF logClient.d  ../../src/log/logClient.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF iocLog.d  ../../src/log/iocLog.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF libComRegister.d  ../../src/iocsh/libComRegister.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF registry.d  ../../src/iocsh/registry.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF iocsh.d  ../../src/iocsh/iocsh.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF gpHashLib.d  ../../src/gpHash/gpHashLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF freeListLib.d  ../../src/freeList/freeListLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF fdManager.d  ../../src/fdmgr/fdManager.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF fdmgr.d  ../../src/fdmgr/fdmgr.cpp
perl -CSD ../../src/error/makeStatTbl.pl  ../../src/osi/devLib.h ../../src/osi/epicsTime.h ../../src/as/asLib.h ../../src/misc/epicsStdlib.h ../../src/pool/epicsThreadPool.h ../../src/error/errMdef.h
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF errSymTbl.d  errSymTbl.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF errSymLib.d  ../../src/error/errSymLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF errlog.d  ../../src/error/errlog.c
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/bldEnvData.pl>  -t yocto21-aarch64 \
	-c gcc -s Linux <http://gfa-sls2-test:8080/job/EPICS-7/ws/configure>
Generating envData.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF envData.d  envData.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF envSubr.d  ../../src/env/envSubr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF ellSort.d  ../../src/ellLib/ellSort.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF ellLib.d  ../../src/ellLib/ellLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF dbmf.d  ../../src/dbmf/dbmf.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF epicsSingletonMutex.d  ../../src/cxxTemplates/epicsSingletonMutex.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF resourceLib.d  ../../src/cxxTemplates/resourceLib.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF cvtFast.d  ../../src/cvtFast/cvtFast.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF calcPerform.d  ../../src/calc/calcPerform.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF postfix.d  ../../src/calc/postfix.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF bucketLib.d  ../../src/bucketLib/bucketLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF asTrapWrite.d  ../../src/as/asTrapWrite.c
<http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/e_flex> -S<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/flex.skel.static> -8 -I -t ../../src/as/asLib_lex.l > asLib_lex.yy.c
mv asLib_lex.yy.c asLib_lex.c
<http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/antelope> -basLib  ../../src/as/asLib.y
mv asLib.tab.c asLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF asLib.d  asLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF warshall.d  ../../src/yacc/warshall.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF verbose.d  ../../src/yacc/verbose.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF symtab.d  ../../src/yacc/symtab.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF skeleton.d  ../../src/yacc/skeleton.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF reader.d  ../../src/yacc/reader.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF output.d  ../../src/yacc/output.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF mkpar.d  ../../src/yacc/mkpar.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF antelope.d  ../../src/yacc/antelope.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF lr0.d  ../../src/yacc/lr0.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF lalr.d  ../../src/yacc/lalr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF error.d  ../../src/yacc/error.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF closure.d  ../../src/yacc/closure.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF iocLogServer.d  ../../src/log/iocLogServer.c
<http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/antelope> -bparse -l -d ../../src/flex/parse.y
mv parse.tab.c parse.c
mv parse.tab.h parse.h
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE       -DDEFAULT_SKELETON_FILE=flex.skel.static   --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF parse.d  parse.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF tblcmp.d  ../../src/flex/tblcmp.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF sym.d  ../../src/flex/sym.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF nfa.d  ../../src/flex/nfa.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF misc.d  ../../src/flex/misc.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF gen.d  ../../src/flex/gen.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF ecs.d  ../../src/flex/ecs.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF dfa.d  ../../src/flex/dfa.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF ccl.d  ../../src/flex/ccl.c
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom/src/O.yocto21-aarch64'>
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom/src/O.yocto21-aarch64'>
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c asLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/as/asTrapWrite.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/bucketLib/bucketLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/calc/postfix.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/calc/calcPerform.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/cvtFast/cvtFast.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/cxxTemplates/resourceLib.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/cxxTemplates/epicsSingletonMutex.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/dbmf/dbmf.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/ellLib/ellLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/ellLib/ellSort.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/env/envSubr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c envData.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/error/errlog.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/error/errSymLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c errSymTbl.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/fdmgr/fdmgr.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/fdmgr/fdManager.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/freeList/freeListLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/gpHash/gpHashLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/iocsh/iocsh.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/iocsh/registry.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/iocsh/libComRegister.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/log/iocLog.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/log/logClient.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/macLib/macCore.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/macLib/macEnv.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/macLib/macUtil.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/misc/alarmString.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/misc/aToIPAddr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/misc/adjustment.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/misc/cantProceed.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/misc/epicsConvert.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/misc/epicsExit.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/misc/epicsStdlib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/misc/epicsString.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/misc/truncateFile.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/misc/ipAddrToAsciiAsynchronous.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/misc/epicsUnitTest.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/epicsThread.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/epicsMutex.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/epicsEvent.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/epicsTime.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/epicsMessageQueue.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/epicsMath.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/epicsAtomicOSD.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/epicsGeneralTime.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/osiClockTime.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/osdSock.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/osdSockAddrReuse.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/osiSock.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/systemCallIntMech.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/default/epicsSocketConvertErrnoToString.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/default/osdAssert.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/osdFindSymbol.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/default/osdInterrupt.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/default/osdPoolStatus.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/osdSignal.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/default/osdEnv.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE        -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/epicsReadline.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/epicsTempFile.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/epicsStdio.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/osdStdio.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/osdThread.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/Linux/osdThreadExtra.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/default/osdThreadHooks.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/osdMutex.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/osdSpin.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/osdEvent.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/osdTime.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/osdMonotonic.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/posix/osdProcess.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/default/osdNetIntf.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/default/osdMessageQueue.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/devLibVME.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/default/devLibVMEOSD.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/epicsStackTrace.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/Linux/osdBackTrace.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/osi/os/Linux/osdFindAddr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/pool/poolJob.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/pool/threadPool.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/ring/epicsRingPointer.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/ring/epicsRingBytes.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/taskwd/taskwd.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/timer/epicsTimer.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/timer/timer.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/timer/timerQueue.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/timer/timerQueueActive.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/timer/timerQueueActiveMgr.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/timer/timerQueuePassive.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yajl/yajl.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yajl/yajl_alloc.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yajl/yajl_buf.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yajl/yajl_encode.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yajl/yajl_gen.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yajl/yajl_lex.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yajl/yajl_parser.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-ar -rc    libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-ranlib libCom.a
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o libCom.so.3.17.0 -shared -fPIC -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic        asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o       -lpthread   -lreadline -lm -lrt -ldl -lgcc
epicsTempFile.o: In function `epicsTempName':
epicsTempFile.cpp:(.text+0x2c): warning: the use of `tmpnam' is dangerous, better use `mkstemp'
Installing shared library <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64/libCom.so.3.17.0>
mkdir <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>
ln -s libCom.so.3.17.0 <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64/libCom.so>
Installing library <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64/libCom.a>
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/flex/ccl.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/flex/dfa.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/flex/ecs.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/flex/gen.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/flex/misc.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/flex/nfa.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/flex/sym.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/flex/tblcmp.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE       -DDEFAULT_SKELETON_FILE=flex.skel.static   --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c parse.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o e_flex  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic        epicsTempFile.o ccl.o dfa.o ecs.o gen.o misc.o nfa.o sym.o tblcmp.o parse.o
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/log/iocLogServer.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o iocLogServer  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic        iocLogServer.o    -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yacc/closure.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yacc/error.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yacc/lalr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yacc/lr0.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yacc/antelope.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yacc/mkpar.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yacc/output.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yacc/reader.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yacc/skeleton.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yacc/symtab.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yacc/verbose.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/Linux -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../src/yacc/warshall.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o antelope  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic        epicsTempFile.o closure.o error.o lalr.o lr0.o antelope.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o
Expanding ../../src/log/S99logServer@ to S99logServer
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/yocto21-aarch64/S99logServer>
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/yocto21-aarch64/bldEnvData.pl>
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/convertRelease.pl> -T ../.. <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/yocto21-aarch64/libcomModuleDirs.pm>
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/yocto21-aarch64/e_flex>
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/yocto21-aarch64/iocLogServer>
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/yocto21-aarch64/antelope>
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom/src/O.yocto21-aarch64'>
make[3]: Target `install' not remade because of errors.
make[3]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom/src'>
make[2]: *** [src.install] Error 2
make[2]: Target `install' not remade because of errors.
make[2]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/libcom'>
make[1]: *** [libcom.install] Error 2
make[1]: Target `install' not remade because of errors.
make[1]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules'>
make: *** [modules.install] Error 2
make: Target `all' not remade because of errors.
Build step 'Execute shell' marked build as failure
Build failed in Jenkins: EPICS-7 #127 Jenkins EPICS PSI
Prev: Re: Launchpad Git repo cleanup Johnson, Andrew N.
Next: Re: EPICS make runtests fails Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : EPICS-3.14 #129 Jenkins EPICS PSI
Next: Build failed in Jenkins: EPICS-7 #127 Jenkins EPICS PSI
ANJ, 17 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
