2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-3.15 #129
To: <[email protected]>, <[email protected]>
Date: Tue, 16 Oct 2018 18:13:21 +0200
See <http://gfa-sls2-test:8080/job/EPICS-3.15/129/display/redirect>
[...truncated 4.60 MB...]
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osdThreadExtra.d  ../../../src/libCom/osi/os/Linux/osdThreadExtra.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osdThread.d  ../../../src/libCom/osi/os/posix/osdThread.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osdStdio.d  ../../../src/libCom/osi/os/posix/osdStdio.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsStdio.d  ../../../src/libCom/osi/epicsStdio.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsTempFile.d  ../../../src/libCom/osi/os/posix/epicsTempFile.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE        -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsReadline.d  ../../../src/libCom/osi/os/default/epicsReadline.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osdEnv.d  ../../../src/libCom/osi/os/default/osdEnv.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osdSignal.d  ../../../src/libCom/osi/os/posix/osdSignal.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osdPoolStatus.d  ../../../src/libCom/osi/os/default/osdPoolStatus.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osdInterrupt.d  ../../../src/libCom/osi/os/default/osdInterrupt.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osdFindSymbol.d  ../../../src/libCom/osi/os/posix/osdFindSymbol.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osdAssert.d  ../../../src/libCom/osi/os/default/osdAssert.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsSocketConvertErrnoToString.d  ../../../src/libCom/osi/os/default/epicsSocketConvertErrnoToString.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF systemCallIntMech.d  ../../../src/libCom/osi/os/posix/systemCallIntMech.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osiSock.d  ../../../src/libCom/osi/osiSock.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osdSockAddrReuse.d  ../../../src/libCom/osi/os/posix/osdSockAddrReuse.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osdSock.d  ../../../src/libCom/osi/os/posix/osdSock.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF osiClockTime.d  ../../../src/libCom/osi/osiClockTime.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsGeneralTime.d  ../../../src/libCom/osi/epicsGeneralTime.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsAtomicOSD.d  ../../../src/libCom/osi/os/posix/epicsAtomicOSD.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsMath.d  ../../../src/libCom/osi/epicsMath.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsMessageQueue.d  ../../../src/libCom/osi/epicsMessageQueue.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsTime.d  ../../../src/libCom/osi/epicsTime.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsEvent.d  ../../../src/libCom/osi/epicsEvent.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsMutex.d  ../../../src/libCom/osi/epicsMutex.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsThread.d  ../../../src/libCom/osi/epicsThread.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsUnitTest.d  ../../../src/libCom/misc/epicsUnitTest.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF ipAddrToAsciiAsynchronous.d  ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF truncateFile.d  ../../../src/libCom/misc/truncateFile.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsString.d  ../../../src/libCom/misc/epicsString.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsStdlib.d  ../../../src/libCom/misc/epicsStdlib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsExit.d  ../../../src/libCom/misc/epicsExit.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsConvert.d  ../../../src/libCom/misc/epicsConvert.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF cantProceed.d  ../../../src/libCom/misc/cantProceed.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF adjustment.d  ../../../src/libCom/misc/adjustment.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF aToIPAddr.d  ../../../src/libCom/misc/aToIPAddr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF alarmString.d  ../../../src/libCom/misc/alarmString.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF macUtil.d  ../../../src/libCom/macLib/macUtil.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF macEnv.d  ../../../src/libCom/macLib/macEnv.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF macCore.d  ../../../src/libCom/macLib/macCore.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF logClient.d  ../../../src/libCom/log/logClient.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF iocLog.d  ../../../src/libCom/log/iocLog.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF libComRegister.d  ../../../src/libCom/iocsh/libComRegister.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF registry.d  ../../../src/libCom/iocsh/registry.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF iocsh.d  ../../../src/libCom/iocsh/iocsh.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF gpHashLib.d  ../../../src/libCom/gpHash/gpHashLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF freeListLib.d  ../../../src/libCom/freeList/freeListLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF fdManager.d  ../../../src/libCom/fdmgr/fdManager.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF fdmgr.d  ../../../src/libCom/fdmgr/fdmgr.cpp
perl -CSD ../../../src/libCom/error/makeStatTbl.pl  ../../../src/libCom/osi/devLib.h ../../../src/libCom/as/asLib.h ../../../src/libCom/misc/epicsStdlib.h ../../../src/libCom/pool/epicsThreadPool.h ../../../src/ioc/db/dbAccessDefs.h ../../../src/ioc/dbStatic/devSup.h ../../../src/ioc/dbStatic/drvSup.h ../../../src/ioc/dbStatic/recSup.h ../../../src/ioc/dbStatic/dbStaticLib.h ../../../src/libCom/error/errMdef.h ../../../src/ca/legacy/pcas/generic/casdef.h ../../../src/ca/legacy/gdd/gddAppFuncTable.h
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF errSymTbl.d  errSymTbl.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF errSymLib.d  ../../../src/libCom/error/errSymLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF errlog.d  ../../../src/libCom/error/errlog.c
perl -CSD ../../../src/libCom/env/bldEnvData.pl  -t yocto21-aarch64 \
	-c gcc -s Linux ../../../configure
Generating envData.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF envData.d  envData.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF envSubr.d  ../../../src/libCom/env/envSubr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF ellSort.d  ../../../src/libCom/ellLib/ellSort.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF ellLib.d  ../../../src/libCom/ellLib/ellLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dbmf.d  ../../../src/libCom/dbmf/dbmf.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsSingletonMutex.d  ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF epicsOnce.d  ../../../src/libCom/cxxTemplates/epicsOnce.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF resourceLib.d  ../../../src/libCom/cxxTemplates/resourceLib.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF cvtFast.d  ../../../src/libCom/cvtFast/cvtFast.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF calcPerform.d  ../../../src/libCom/calc/calcPerform.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF postfix.d  ../../../src/libCom/calc/postfix.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF bucketLib.d  ../../../src/libCom/bucketLib/bucketLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF asTrapWrite.d  ../../../src/libCom/as/asTrapWrite.c
<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/bin/RHEL7-x86_64/e_flex> -S../../../include/flex.skel.static -8 -I -oasLib_lex.c ../../../src/libCom/as/asLib_lex.l
<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/bin/RHEL7-x86_64/antelope> -basLib  ../../../src/libCom/as/asLib.y
mv asLib.tab.c asLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF asLib.d  asLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF warshall.d  ../../../src/libCom/yacc/warshall.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF verbose.d  ../../../src/libCom/yacc/verbose.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF symtab.d  ../../../src/libCom/yacc/symtab.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF skeleton.d  ../../../src/libCom/yacc/skeleton.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF reader.d  ../../../src/libCom/yacc/reader.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF output.d  ../../../src/libCom/yacc/output.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF mkpar.d  ../../../src/libCom/yacc/mkpar.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF antelope.d  ../../../src/libCom/yacc/antelope.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF lr0.d  ../../../src/libCom/yacc/lr0.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF lalr.d  ../../../src/libCom/yacc/lalr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF error.d  ../../../src/libCom/yacc/error.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF closure.d  ../../../src/libCom/yacc/closure.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF iocLogServer.d  ../../../src/libCom/log/iocLogServer.c
<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/bin/RHEL7-x86_64/antelope> -bparse -l -d ../../../src/libCom/flex/parse.y
mv parse.tab.c parse.c
mv parse.tab.h parse.h
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DDEFAULT_SKELETON_FILE=flex.skel.static   --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF parse.d  parse.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF tblcmp.d  ../../../src/libCom/flex/tblcmp.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF sym.d  ../../../src/libCom/flex/sym.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF nfa.d  ../../../src/libCom/flex/nfa.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF misc.d  ../../../src/libCom/flex/misc.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF gen.d  ../../../src/libCom/flex/gen.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF ecs.d  ../../../src/libCom/flex/ecs.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF dfa.d  ../../../src/libCom/flex/dfa.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF ccl.d  ../../../src/libCom/flex/ccl.c
make[3]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/src/libCom/O.yocto21-aarch64'>
make[3]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/src/libCom/O.yocto21-aarch64'>
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c asLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/as/asTrapWrite.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/bucketLib/bucketLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/calc/postfix.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/calc/calcPerform.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/cvtFast/cvtFast.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/cxxTemplates/resourceLib.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/cxxTemplates/epicsOnce.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/cxxTemplates/epicsSingletonMutex.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/dbmf/dbmf.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/ellLib/ellLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/ellLib/ellSort.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/env/envSubr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c envData.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/error/errlog.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/error/errSymLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c errSymTbl.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/fdmgr/fdmgr.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/fdmgr/fdManager.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/freeList/freeListLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/gpHash/gpHashLib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/iocsh/iocsh.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/iocsh/registry.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/iocsh/libComRegister.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/log/iocLog.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/log/logClient.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/macLib/macCore.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/macLib/macEnv.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/macLib/macUtil.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/misc/alarmString.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/misc/aToIPAddr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/misc/adjustment.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/misc/cantProceed.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/misc/epicsConvert.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/misc/epicsExit.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/misc/epicsStdlib.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/misc/epicsString.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/misc/truncateFile.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/misc/ipAddrToAsciiAsynchronous.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/misc/epicsUnitTest.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/epicsThread.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/epicsMutex.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/epicsEvent.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/epicsTime.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/epicsMessageQueue.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/epicsMath.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/epicsAtomicOSD.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/epicsGeneralTime.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/osiClockTime.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/osdSock.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/osdSockAddrReuse.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/osiSock.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/systemCallIntMech.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/default/epicsSocketConvertErrnoToString.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/default/osdAssert.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/osdFindSymbol.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/default/osdInterrupt.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/default/osdPoolStatus.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/osdSignal.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/default/osdEnv.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE        -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/default/epicsReadline.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/epicsTempFile.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/epicsStdio.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/osdStdio.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/osdThread.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/Linux/osdThreadExtra.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/default/osdThreadHooks.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/osdMutex.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/osdSpin.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/osdEvent.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/osdTime.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/osdProcess.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/default/osdNetIntf.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/default/osdMessageQueue.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/devLibVME.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/default/devLibVMEOSD.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/epicsStackTrace.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/Linux/osdBackTrace.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/Linux/osdFindAddr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/pool/poolJob.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/pool/threadPool.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/ring/epicsRingPointer.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/ring/epicsRingBytes.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/taskwd/taskwd.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/timer/epicsTimer.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/timer/timer.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/timer/timerQueue.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/timer/timerQueueActive.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/timer/timerQueueActiveMgr.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/timer/timerQueuePassive.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yajl/yajl.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yajl/yajl_alloc.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yajl/yajl_buf.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yajl/yajl_encode.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yajl/yajl_gen.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yajl/yajl_lex.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yajl/yajl_parser.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-ar -rc    libCom.a        asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-ranlib libCom.a
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o libCom.so.3.15.6 -shared -fPIC -L<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic            asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o       -lpthread   -lreadline -lm -lrt -ldl -lgcc
epicsTempFile.o: In function `epicsTempName':
epicsTempFile.cpp:(.text+0x2c): warning: the use of `tmpnam' is dangerous, better use `mkstemp'
Installing shared library ../../../lib/yocto21-aarch64/libCom.so.3.15.6
mkdir ../../../lib/yocto21-aarch64
ln -s libCom.so.3.15.6 ../../../lib/yocto21-aarch64/libCom.so
Installing library ../../../lib/yocto21-aarch64/libCom.a
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/flex/ccl.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/flex/dfa.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/flex/ecs.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/flex/gen.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/flex/misc.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/flex/nfa.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/flex/sym.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/flex/tblcmp.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DDEFAULT_SKELETON_FILE=flex.skel.static   --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall           -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c parse.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o e_flex  -L<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic            epicsTempFile.o ccl.o dfa.o ecs.o gen.o misc.o nfa.o sym.o tblcmp.o parse.o
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/log/iocLogServer.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o iocLogServer  -L<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic            iocLogServer.o    -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yacc/closure.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yacc/error.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yacc/lalr.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yacc/lr0.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yacc/antelope.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yacc/mkpar.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yacc/output.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yacc/reader.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yacc/skeleton.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yacc/symtab.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yacc/verbose.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/yacc/warshall.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o antelope  -L<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic            epicsTempFile.o closure.o error.o lalr.o lr0.o antelope.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o
Expanding ../../../src/libCom/log/S99logServer@ to S99logServer
Installing created executable ../../../bin/yocto21-aarch64/S99logServer
Installing created executable ../../../bin/yocto21-aarch64/e_flex
Installing created executable ../../../bin/yocto21-aarch64/iocLogServer
Installing created executable ../../../bin/yocto21-aarch64/antelope
make[3]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/src/libCom/O.yocto21-aarch64'>
make[2]: Target `install' not remade because of errors.
make[2]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/src/libCom'>
make[1]: *** [libCom.install] Error 2
make[1]: Target `install' not remade because of errors.
make[1]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-3.15/ws/src'>
make: *** [src.install] Error 2
make: Target `all' not remade because of errors.
Build step 'Execute shell' marked build as failure
Build failed in Jenkins: EPICS-3.15 #130 Jenkins EPICS PSI
Build failed in Jenkins: EPICS-3.15 #128 Jenkins EPICS PSI
Prev: Re: EPICS make runtests fails Johnson, Andrew N.
Next: Build failed in Jenkins: EPICS-3.16 #126 Jenkins EPICS PSI
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: EPICS-3.15 #128 Jenkins EPICS PSI
Next: Build failed in Jenkins: EPICS-3.15 #130 Jenkins EPICS PSI
ANJ, 16 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
