2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-7.0-windows » STATIC,win64 #61
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 26 Oct 2018 18:28:25 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/61/display/redirect?page=changes>
Changes:
[Michael Davidsaver] libCom/misc: testMain for RTEMS give weak alias for main()
[Michael Davidsaver] src/tools: teach makeTestfile about WINE and QEMU
[Michael Davidsaver] RTEMS: Add epicsMemFs and hook for app specific FS setup
[Michael Davidsaver] RTEMS: build self contained test harness
[Michael Davidsaver] build/run RTEMS-pc386 tests individually
[Michael Davidsaver] libCom/test: only run epicsUnitTest for host arch
[Michael Davidsaver] db/test: dbStressLock skip for RTEMS
[Michael Davidsaver] RTEMS: probe for PCI varient of NE2000 NIC
[Michael Davidsaver] RTEMS: conditional fixups for pc386
[Michael Davidsaver] rtems tests for pc386
[Michael Davidsaver] travis-ci: run tests with RTEMS pc386/qemu
[Andrew Johnson] Remove duplicate variables from lnkCalc.c
[Andrew Johnson] Add a "state" link type using the dbState API
[Andrew Johnson] lnkState: Add support for inverting the flag data
[Andrew Johnson] dbJLink: Handle NULL returned by jlif::alloc() better
[Andrew Johnson] Cleanup warnings in lnkConst.c
[Andrew Johnson] More timestamp support for lnkCalc
[Andrew Johnson] Replace the base:jlinkDebug info-item with a global variable
[Andrew Johnson] Export dbJLinkDebug as a shell variable
[Andrew Johnson] Remove final traces of link debug info tags
[Andrew Johnson] Added DBF_OUTLINK support to lnkCalc
[Andrew Johnson] dbLink: Clarify meaning of lset isConstant and isVolatile flags
[Andrew Johnson] lnkState: Mark as non-volatile, remove lset::isConnected() method
[Andrew Johnson] Added C++ extern "C" wrapper to dbState.h
[Andrew Johnson] Added Doxygen annotations for the Link Support API
[Michael Davidsaver] propagate PUTF through DB_LINK and use to RPRO async
[Michael Davidsaver] start asyncproctest
[Michael Davidsaver] ioc/dbStatic: add typed_dset
[Michael Davidsaver] ioc/dbStatic: add typed_drvet
[Michael Davidsaver] ioc/dbStatic: add dbGetDevLink()
[Michael Davidsaver] std/rec/test: test
[Michael Davidsaver] add release note
[Michael Davidsaver] add USE_TYPED_DRVET and USE_TYPED_DSET options
[Andrew Johnson] dbJLink: Pass the correct dbfType to child links
[Andrew Johnson] Add jlif::start_child() method
[Andrew Johnson] dbJLink: Add jlif result enum state name strings
[Andrew Johnson] dbJLink: Restore the jlink::debug flag, add debug and trace link types
[Andrew Johnson] Link types: Remove debug tracing now provided by debug link type
[Andrew Johnson] Update Release Notes with link-updates changes
[Andrew Johnson] New src/std/link/test directory with tests for the state link type
[Andrew Johnson] lnkStateTest: set testPlan
[Andrew Johnson] dbJLink: Some extra checks at parse/init time
[Andrew Johnson] lnkDebug fix: Initialize child link's precord pointer
[Andrew Johnson] lnkDebug: Fix typo in getAlarm range checks
[Andrew Johnson] lnkCalc fix: Don't evaluate minor expression when major returned true
[Andrew Johnson] lnkStateTest: Show status value in test output
[Andrew Johnson] Added lnkCalcTest
[Andrew Johnson] Fix warnings from clang
[Andrew Johnson] startup: Update win*.bat files
[Michael Davidsaver] rtemsttest generalize condition for individual tests
[Michael Davidsaver] use new RTEMS build
[Michael Davidsaver] travis-ci: remove unused
[Andrew Johnson] Move EpicsHostArch.pl into src/tools, install to lib/perl
[Andrew Johnson] Start release notes for tidy-startup branch.
[jlmuir] Rename Site.{cshrc,profile} to unix.{csh,sh}
[jlmuir] Remove EpicsHostArch
[jlmuir] Remove execute file mode bit
[jlmuir] Make EpicsHostArch.pl print newline
[Andrew Johnson] Documentation updates for 3.14.12.8
[Andrew Johnson] Update version number to 3.14.12.8-rc1
[Andrew Johnson] Post-tag version number update
[jlmuir] Remove startup/cygwin.bat
[jlmuir] Rewrite startup/unix.sh
[jlmuir] Rewrite startup/unix.csh
[jlmuir] Rewrite startup/win32.bat
[jlmuir] Rewrite startup/windows.bat
[jlmuir] Remove execute file mode bit on EpicsHostArch.pl
[jlmuir] Remove trailing space in license of startup/unix.*
[Andrew Johnson] Fix for lp: #1730727
[Andrew Johnson] Add missing includes for db_post_events()
[Andrew Johnson] libCom: Add and use a -o<filename> option to e_flex
[Andrew Johnson] Fix for lp: #1503661
[Andrew Johnson] msi: Source code reformatting, typo fixes, unify messages
[Andrew Johnson] recGbl: Prevent record alarm severities > INVALID_ALARM
[Andrew Johnson] caget.pl: Add missing acks and ackt metadata to display output
[Andrew Johnson] Move dbScanPassive() into dbDbLink.c, create processTarget()
[Andrew Johnson] Improved and extended the PUTF/RPRO tests
[Andrew Johnson] Release notes for PUTF/RPRO update
[konrad] Add missing incude in dbLock.h
[Andrew Johnson] Update/clean up EpicsHostArch.pl
[Andrew Johnson] Remove macLib warning indicators
[Andrew Johnson] Added a simpler startup/EpicsHostArch for backwards-compatibility
[konrad] iocLogserver: allow log file limit to be disabled
[Andrew Johnson] osiClockTime: Only call clock_setting() on embedded OSs
[Andrew Johnson] Fix for lp: #1786320
[Andrew Johnson] Add fix to Release Notes
[Andrew Johnson] osiClockTime again: Don't compile ClockTimeSync() on iOS either
[Andrew Johnson] Latest Xcode also doesn't like compiling system() for iOS
[Michael Davidsaver] travis-ci: install qemu
[Michael Davidsaver] ioc/db/test: dbParseLink test handle NULL
[Michael Davidsaver] ioc/dbStatic: HW links allow optional '@'
[Michael Davidsaver] db/test: Check that junk before '@' fails w/ INST_IO
[Ralph Lange] libcom/osi/windows: log errors using fprintf() instead of pop-up (fixes
[konrad] Fix "make --question" mode
[Andrew Johnson] Fix shebang line in makeInstallDir.pl
[Andrew Johnson] Update README's list of files
[Andrew Johnson] configure/CONFIG: Undefine EHA after use
[konrad] Make EpicsHostArch compatible with sh
[Andrew Johnson] Make startup/EpicsHostArch script executable
[Andrew Johnson] startup: Fix EHA argument quoting per J. Lewis Muir
[Andrew Johnson] Release notes about iocLogServer
[Andrew Johnson] Set EPICS_DEV_SNAPSHOT for the final 3.14.12.8 release
[Andrew Johnson] GNU Make 3.81 (as used on Travis) doesn't have 'undefine'
[Andrew Johnson] Darwin: Don't link using -flat_namespace
[dirk.zimoch] implement epicsEnvUnset
[dirk.zimoch] remove compiler warning
[Ralph Lange] libCom/osi: Add epicsStdio functions to std namespace; allow to skip
[Ralph Lange] doc: update release checklist
[Ralph Lange] Update version to 3.15.6-rc1
[Ralph Lange] Version number update to 3.15.6-rc1-DEV
[Andrew Johnson] Adjust the 'git archive' commands in Release Checklist
[dirk.zimoch] add missing epicsEnvUnset to header
[dirk.zimoch] added simple test case for epicsEnvUnset
[dirk.zimoch] mention epicsEnvUnset in RELEASE_NOTES.html
[Ralph Lange] libCom/osi: fix recent epicsStdio.h change for gcc 2.x
[Ralph Lange] configure: add vpath for CONFIG* and RULES* (look in SRC_DIRS)
[Andrew Johnson] Revert "configure: add vpath for CONFIG* and RULES* (look in SRC_DIRS)"
[Ralph Lange] libCom/osi: fix epicsEnvUnset for WIN32 and solaris
[Ralph Lange] Update version to 3.15.6, remove "not released" from release notes
[Ralph Lange] Set version to 3.15.6-DEV, prepare new release notes chapter
[konrad] Fix shebang line of tap-to-junit-xml.pl
[Andrew Johnson] Add RULES_COMMON
[Andrew Johnson] Unify header comments in configure/RULES files
[Andrew Johnson] Why was RULES_BUILD using -include for other Base RULES files?
[Andrew Johnson] Warn on multiple inclusion of RULES_BUILD
[Andrew Johnson] Correct mbbi/oDirect release note entry
[Andrew Johnson] Improve devSup example
[Michael Davidsaver] setsockopt size IP_MULTICAST_TTL
[Michael Davidsaver] libCom/test cover IP_MULTICAST_TTL
[Andrew Johnson] Fix show-makefiles rule for files containing colons
[Andrew Johnson] Add missing dependency for parallel builds in std/link/test
[Andrew Johnson] VxWorks build warning
[Andrew Johnson] Declare IOSCANPVT in devSup.h only
[Andrew Johnson] Make example get_ioint_info() routine static
[Andrew Johnson] Require RTEMS_BSP to be set in CONFIG.Common.RTEMS-<arch>
[Andrew Johnson] Add RTEMS-pc368-qemu target, use in Travis-CI builds
[Andrew Johnson] T_A can never contain spaces
[Andrew Johnson] Minor Perl tidying up
[Andrew Johnson] Don't require older RTEMS arch's to set RTEMS_BSP
[Andrew Johnson] Release Notes for the rtems-test branch
[Andrew Johnson] Fix MUNCH_CMD for RTEMS-pc386 with parallel builds
[Andrew Johnson] RTEMS use non-default osdEnv
[Andrew Johnson] yajlTest doesn't run w/ RTEMS+qemu
[Andrew Johnson] Improve output from genVersionHeader.pl
[Andrew Johnson] Set version to 3.16.2-rc1
[Andrew Johnson] Set version to -DEV after -rc1 tagged
[Andrew Johnson] Clean-up of aai and waveform record sources
[Andrew Johnson] Rework epicsMakeMemFs.pl script to use higher level constructs
[...truncated 2.41 MB...]
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/modules/pvaClient/src/O.windows-x64-static'>
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/modules/pvaClient/src/O.windows-x64-static'>
cl -EHsc -GR               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c ../pvaClientNTMultiMonitor.cpp
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\include\pv\pvdata.h(508): warning C4800: 'char': forcing value to bool 'true' or 'false' (performance warning)
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\include\pv\pvdata.h(558): warning C4250: 'epics::pvData::PVString': inherits 'epics::pvData::PVScalarValue<std::string>::epics::pvData::PVScalarValue<std::string>::deserialize' via dominance
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\include\pv\pvdata.h(461): note: see declaration of 'epics::pvData::PVScalarValue<std::string>::deserialize'
make -C ./testApp install
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/modules/pva2pva/testApp'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/makeMakefile.pl> O.windows-x64-static ../..
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/modules/pva2pva/testApp'>
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64-static -f ../Makefile TOP=../.. \
    T_A=windows-x64-static install
cl -EHsc -GR               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c ../pvaClientRPC.cpp
pvaClientRPC.cpp
lib -nologo -verbose -out:pvaClient.lib     pvaClient.obj pvaClientPutData.obj pvaClientGetData.obj pvaClientMonitorData.obj pvaClientChannel.obj pvaClientProcess.obj pvaClientGet.obj pvaClientPut.obj pvaClientMonitor.obj pvaClientPutGet.obj pvaClientMultiChannel.obj pvaClientMultiGetDouble.obj pvaClientMultiPutDouble.obj pvaClientMultiMonitorDouble.obj pvaClientNTMultiPut.obj pvaClientNTMultiData.obj pvaClientNTMultiGet.obj pvaClientNTMultiMonitor.obj pvaClientRPC.obj
Appending pvaClientRPC.obj
Appending pvaClientNTMultiMonitor.obj
Appending pvaClientNTMultiGet.obj
Appending pvaClientNTMultiData.obj
Appending pvaClientNTMultiPut.obj
Appending pvaClientMultiMonitorDouble.obj
Appending pvaClientMultiPutDouble.obj
Appending pvaClientMultiGetDouble.obj
Appending pvaClientMultiChannel.obj
Appending pvaClientPutGet.obj
Appending pvaClientMonitor.obj
Appending pvaClientPut.obj
Appending pvaClientGet.obj
Appending pvaClientProcess.obj
Appending pvaClientChannel.obj
Appending pvaClientMonitorData.obj
Appending pvaClientGetData.obj
Appending pvaClientPutData.obj
Appending pvaClient.obj
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/modules/pva2pva/testApp/O.windows-x64-static'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/mkmf.pl>  -m check_consist.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        check_consist.obj ../check_consist.cpp
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/modules/pva2pva/testApp/O.windows-x64-static'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/mkmf.pl>  -m testgroupconfig.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        testgroupconfig.obj ../testgroupconfig.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/mkmf.pl>  -m testdbf_copy.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        testdbf_copy.obj ../testdbf_copy.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/mkmf.pl>  -m testpvalink.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        testpvalink.obj ../testpvalink.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/dbdExpand.pl>   -I. -I.. -I../O.Common -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/dbd> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/dbd> -o pvaLinkTestIoc.dbd base.dbd qsrv.dbd
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/mkmf.pl>  -m testpdb.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        testpdb.obj ../testpdb.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/mkmf.pl>  -m testweak.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        testweak.obj ../testweak.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/mkmf.pl>  -m testpvif.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        testpvif.obj ../testpvif.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/mkmf.pl>  -m testtest.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        testtest.obj ../testtest.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/dbdExpand.pl>   -I. -I.. -I../O.Common -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/dbd> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/dbd> -o p2pTestIoc.dbd base.dbd
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/mkmf.pl>  -m utilitiesx.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        utilitiesx.obj ../utilitiesx.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/registerRecordDeviceDriver.pl>   -I. -I.. -I../O.Common -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/dbd> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/dbd>    -o pvaLinkTestIoc_registerRecordDeviceDriver.cpp ../O.Common/pvaLinkTestIoc.dbd pvaLinkTestIoc_registerRecordDeviceDriver <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/registerRecordDeviceDriver.pl>   -I. -I.. -I../O.Common -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/dbd> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/dbd>    -o p2pTestIoc_registerRecordDeviceDriver.cpp ../O.Common/p2pTestIoc.dbd p2pTestIoc_registerRecordDeviceDriver <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/mkmf.pl>  -m pvaLinkTestIoc_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        pvaLinkTestIoc_registerRecordDeviceDriver.obj pvaLinkTestIoc_registerRecordDeviceDriver.cpp
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/mkmf.pl>  -m p2pTestIoc_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        p2pTestIoc_registerRecordDeviceDriver.obj p2pTestIoc_registerRecordDeviceDriver.cpp
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c ../testweak.cpp
testweak.cpp
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c ../check_consist.cpp
check_consist.cpp
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c p2pTestIoc_registerRecordDeviceDriver.cpp
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c ../testtest.cpp
testtest.cpp
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c ../utilitiesx.cpp
utilitiesx.cpp
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c pvaLinkTestIoc_registerRecordDeviceDriver.cpp
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c ../testpvif.cpp
testpvif.cpp
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(201): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(260): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(267): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(274): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(281): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(288): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(347): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(356): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(365): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(374): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(386): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(393): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(400): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpvif.cpp(407): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c ../testpvalink.cpp
testpvalink.cpp
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c ../testgroupconfig.cpp
testgroupconfig.cpp
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c ../testpdb.cpp
testpdb.cpp
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpdb.cpp(153): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpdb.cpp(168): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpdb.cpp(169): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpdb.cpp(223): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testpdb.cpp(282): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
link -nologo   -incremental:no -opt:ref -release  -MACHINE:X64              -out:check_consist.exe   check_consist.obj utilitiesx.obj     <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/Com.lib>  ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -Oy-   -W3 -w44355 -w44344 -w44251        -MT  -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/include>        -c ../testdbf_copy.cpp
testdbf_copy.cpp
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testdbf_copy.cpp(204): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testdbf_copy.cpp(225): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testdbf_copy.cpp(144): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testdbf_copy.cpp(253): note: see reference to function template instantiation 'void `anonymous-namespace'::testDBR2PVD_scalar<double,double>(const input_t &,const output_t &)' being compiled
        with
            input_t=double,
            output_t=double
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testdbf_copy.cpp(180): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\static\os\win64\modules\pva2pva\testapp\testdbf_copy.cpp(260): note: see reference to function template instantiation 'void `anonymous-namespace'::testDBR2PVD_enum<epics::pvData::uint32>(const input_t &,epics::pvData::int32)' being compiled
        with
            input_t=epics::pvData::uint32
link -nologo   -incremental:no -opt:ref -release  -MACHINE:X64              -out:testweak.exe   testweak.obj utilitiesx.obj    <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/Com.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/Com.lib>  ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
link -nologo   -incremental:no -opt:ref -release  -MACHINE:X64              -out:testtest.exe   testtest.obj utilitiesx.obj     <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/Com.lib>  ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
link -nologo   -incremental:no -opt:ref -release  -MACHINE:X64              -out:testpvif.exe   testpvif.obj p2pTestIoc_registerRecordDeviceDriver.obj utilitiesx.obj    <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/qsrv.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/Com.lib>  ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
link -nologo   -incremental:no -opt:ref -release  -MACHINE:X64              -out:testpdb.exe   testpdb.obj p2pTestIoc_registerRecordDeviceDriver.obj utilitiesx.obj    <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/qsrv.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/Com.lib>  ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
link -nologo   -incremental:no -opt:ref -release  -MACHINE:X64              -out:testpvalink.exe   testpvalink.obj pvaLinkTestIoc_registerRecordDeviceDriver.obj utilitiesx.obj    <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/qsrv.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/Com.lib>  ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/makeTestfile.pl> windows-x64-static windows-x64-static testtest.t testtest.exe
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/makeTestfile.pl> windows-x64-static windows-x64-static testweak.t testweak.exe
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/makeTestfile.pl> windows-x64-static windows-x64-static testpdb.t testpdb.exe
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/makeTestfile.pl> windows-x64-static windows-x64-static testpvif.t testpvif.exe
link -nologo   -incremental:no -opt:ref -release  -MACHINE:X64              -out:testgroupconfig.exe   testgroupconfig.obj utilitiesx.obj    <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/qsrv.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/Com.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/Com.lib>  ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/makeTestfile.pl> windows-x64-static windows-x64-static testpvalink.t testpvalink.exe
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/makeTestfile.pl> windows-x64-static windows-x64-static testgroupconfig.t testgroupconfig.exe
link -nologo   -incremental:no -opt:ref -release  -MACHINE:X64              -out:testdbf_copy.exe   testdbf_copy.obj utilitiesx.obj    <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/qsrv.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/Com.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/lib/windows-x64-static/Com.lib>  ws2_32.lib advapi32.lib user32.lib kernel32.lib winmm.lib
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=STATIC,OS=win64/ws/bin/windows-x64-static/makeTestfile.pl> windows-x64-static windows-x64-static testdbf_copy.t testdbf_copy.exe
make -C ./iocBoot install
make -C ./iocwfdemo install
make -C ./iocpvalink install
make -C ./iocimagedemo install
make[4]: Nothing to be done for 'install'.
configure/RULES_DIRS:84: recipe for target 'modules.install' failed
make: *** [modules.install] Error 2
Build step 'Execute Windows batch command' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-7.0-windows » STATIC,win64 #62 APS Jenkins via Core-talk
Build failed in Jenkins: epics-7.0-windows » STATIC,win64 #60 APS Jenkins
Prev: Build failed in Jenkins: epics-7.0-windows » STATIC,win32 #61 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-7.0-windows » DLL, win64 #61 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-7.0-windows » STATIC,win64 #60 APS Jenkins
Next: Build failed in Jenkins: epics-7.0-windows » STATIC,win64 #62 APS Jenkins via Core-talk
ANJ, 29 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
