2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-7.0-windows » DLL, win64 #61
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 26 Oct 2018 18:48:20 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/61/display/redirect?page=changes>
Changes:
[Michael Davidsaver] libCom/misc: testMain for RTEMS give weak alias for main()
[Michael Davidsaver] src/tools: teach makeTestfile about WINE and QEMU
[Michael Davidsaver] RTEMS: Add epicsMemFs and hook for app specific FS setup
[Michael Davidsaver] RTEMS: build self contained test harness
[Michael Davidsaver] build/run RTEMS-pc386 tests individually
[Michael Davidsaver] libCom/test: only run epicsUnitTest for host arch
[Michael Davidsaver] db/test: dbStressLock skip for RTEMS
[Michael Davidsaver] RTEMS: probe for PCI varient of NE2000 NIC
[Michael Davidsaver] RTEMS: conditional fixups for pc386
[Michael Davidsaver] rtems tests for pc386
[Michael Davidsaver] travis-ci: run tests with RTEMS pc386/qemu
[Andrew Johnson] Remove duplicate variables from lnkCalc.c
[Andrew Johnson] Add a "state" link type using the dbState API
[Andrew Johnson] lnkState: Add support for inverting the flag data
[Andrew Johnson] dbJLink: Handle NULL returned by jlif::alloc() better
[Andrew Johnson] Cleanup warnings in lnkConst.c
[Andrew Johnson] More timestamp support for lnkCalc
[Andrew Johnson] Replace the base:jlinkDebug info-item with a global variable
[Andrew Johnson] Export dbJLinkDebug as a shell variable
[Andrew Johnson] Remove final traces of link debug info tags
[Andrew Johnson] Added DBF_OUTLINK support to lnkCalc
[Andrew Johnson] dbLink: Clarify meaning of lset isConstant and isVolatile flags
[Andrew Johnson] lnkState: Mark as non-volatile, remove lset::isConnected() method
[Andrew Johnson] Added C++ extern "C" wrapper to dbState.h
[Andrew Johnson] Added Doxygen annotations for the Link Support API
[Michael Davidsaver] propagate PUTF through DB_LINK and use to RPRO async
[Michael Davidsaver] start asyncproctest
[Michael Davidsaver] ioc/dbStatic: add typed_dset
[Michael Davidsaver] ioc/dbStatic: add typed_drvet
[Michael Davidsaver] ioc/dbStatic: add dbGetDevLink()
[Michael Davidsaver] std/rec/test: test
[Michael Davidsaver] add release note
[Michael Davidsaver] add USE_TYPED_DRVET and USE_TYPED_DSET options
[Andrew Johnson] dbJLink: Pass the correct dbfType to child links
[Andrew Johnson] Add jlif::start_child() method
[Andrew Johnson] dbJLink: Add jlif result enum state name strings
[Andrew Johnson] dbJLink: Restore the jlink::debug flag, add debug and trace link types
[Andrew Johnson] Link types: Remove debug tracing now provided by debug link type
[Andrew Johnson] Update Release Notes with link-updates changes
[Andrew Johnson] New src/std/link/test directory with tests for the state link type
[Andrew Johnson] lnkStateTest: set testPlan
[Andrew Johnson] dbJLink: Some extra checks at parse/init time
[Andrew Johnson] lnkDebug fix: Initialize child link's precord pointer
[Andrew Johnson] lnkDebug: Fix typo in getAlarm range checks
[Andrew Johnson] lnkCalc fix: Don't evaluate minor expression when major returned true
[Andrew Johnson] lnkStateTest: Show status value in test output
[Andrew Johnson] Added lnkCalcTest
[Andrew Johnson] Fix warnings from clang
[Andrew Johnson] startup: Update win*.bat files
[Michael Davidsaver] rtemsttest generalize condition for individual tests
[Michael Davidsaver] use new RTEMS build
[Michael Davidsaver] travis-ci: remove unused
[Andrew Johnson] Move EpicsHostArch.pl into src/tools, install to lib/perl
[Andrew Johnson] Start release notes for tidy-startup branch.
[jlmuir] Rename Site.{cshrc,profile} to unix.{csh,sh}
[jlmuir] Remove EpicsHostArch
[jlmuir] Remove execute file mode bit
[jlmuir] Make EpicsHostArch.pl print newline
[Andrew Johnson] Documentation updates for 3.14.12.8
[Andrew Johnson] Update version number to 3.14.12.8-rc1
[Andrew Johnson] Post-tag version number update
[jlmuir] Remove startup/cygwin.bat
[jlmuir] Rewrite startup/unix.sh
[jlmuir] Rewrite startup/unix.csh
[jlmuir] Rewrite startup/win32.bat
[jlmuir] Rewrite startup/windows.bat
[jlmuir] Remove execute file mode bit on EpicsHostArch.pl
[jlmuir] Remove trailing space in license of startup/unix.*
[Andrew Johnson] Fix for lp: #1730727
[Andrew Johnson] Add missing includes for db_post_events()
[Andrew Johnson] libCom: Add and use a -o<filename> option to e_flex
[Andrew Johnson] Fix for lp: #1503661
[Andrew Johnson] msi: Source code reformatting, typo fixes, unify messages
[Andrew Johnson] recGbl: Prevent record alarm severities > INVALID_ALARM
[Andrew Johnson] caget.pl: Add missing acks and ackt metadata to display output
[Andrew Johnson] Move dbScanPassive() into dbDbLink.c, create processTarget()
[Andrew Johnson] Improved and extended the PUTF/RPRO tests
[Andrew Johnson] Release notes for PUTF/RPRO update
[konrad] Add missing incude in dbLock.h
[Andrew Johnson] Update/clean up EpicsHostArch.pl
[Andrew Johnson] Remove macLib warning indicators
[Andrew Johnson] Added a simpler startup/EpicsHostArch for backwards-compatibility
[konrad] iocLogserver: allow log file limit to be disabled
[Andrew Johnson] osiClockTime: Only call clock_setting() on embedded OSs
[Andrew Johnson] Fix for lp: #1786320
[Andrew Johnson] Add fix to Release Notes
[Andrew Johnson] osiClockTime again: Don't compile ClockTimeSync() on iOS either
[Andrew Johnson] Latest Xcode also doesn't like compiling system() for iOS
[Michael Davidsaver] travis-ci: install qemu
[Michael Davidsaver] ioc/db/test: dbParseLink test handle NULL
[Michael Davidsaver] ioc/dbStatic: HW links allow optional '@'
[Michael Davidsaver] db/test: Check that junk before '@' fails w/ INST_IO
[Ralph Lange] libcom/osi/windows: log errors using fprintf() instead of pop-up (fixes
[konrad] Fix "make --question" mode
[Andrew Johnson] Fix shebang line in makeInstallDir.pl
[Andrew Johnson] Update README's list of files
[Andrew Johnson] configure/CONFIG: Undefine EHA after use
[konrad] Make EpicsHostArch compatible with sh
[Andrew Johnson] Make startup/EpicsHostArch script executable
[Andrew Johnson] startup: Fix EHA argument quoting per J. Lewis Muir
[Andrew Johnson] Release notes about iocLogServer
[Andrew Johnson] Set EPICS_DEV_SNAPSHOT for the final 3.14.12.8 release
[Andrew Johnson] GNU Make 3.81 (as used on Travis) doesn't have 'undefine'
[Andrew Johnson] Darwin: Don't link using -flat_namespace
[dirk.zimoch] implement epicsEnvUnset
[dirk.zimoch] remove compiler warning
[Ralph Lange] libCom/osi: Add epicsStdio functions to std namespace; allow to skip
[Ralph Lange] doc: update release checklist
[Ralph Lange] Update version to 3.15.6-rc1
[Ralph Lange] Version number update to 3.15.6-rc1-DEV
[Andrew Johnson] Adjust the 'git archive' commands in Release Checklist
[dirk.zimoch] add missing epicsEnvUnset to header
[dirk.zimoch] added simple test case for epicsEnvUnset
[dirk.zimoch] mention epicsEnvUnset in RELEASE_NOTES.html
[Ralph Lange] libCom/osi: fix recent epicsStdio.h change for gcc 2.x
[Ralph Lange] configure: add vpath for CONFIG* and RULES* (look in SRC_DIRS)
[Andrew Johnson] Revert "configure: add vpath for CONFIG* and RULES* (look in SRC_DIRS)"
[Ralph Lange] libCom/osi: fix epicsEnvUnset for WIN32 and solaris
[Ralph Lange] Update version to 3.15.6, remove "not released" from release notes
[Ralph Lange] Set version to 3.15.6-DEV, prepare new release notes chapter
[konrad] Fix shebang line of tap-to-junit-xml.pl
[Andrew Johnson] Add RULES_COMMON
[Andrew Johnson] Unify header comments in configure/RULES files
[Andrew Johnson] Why was RULES_BUILD using -include for other Base RULES files?
[Andrew Johnson] Warn on multiple inclusion of RULES_BUILD
[Andrew Johnson] Correct mbbi/oDirect release note entry
[Andrew Johnson] Improve devSup example
[Michael Davidsaver] setsockopt size IP_MULTICAST_TTL
[Michael Davidsaver] libCom/test cover IP_MULTICAST_TTL
[Andrew Johnson] Fix show-makefiles rule for files containing colons
[Andrew Johnson] Add missing dependency for parallel builds in std/link/test
[Andrew Johnson] VxWorks build warning
[Andrew Johnson] Declare IOSCANPVT in devSup.h only
[Andrew Johnson] Make example get_ioint_info() routine static
[Andrew Johnson] Require RTEMS_BSP to be set in CONFIG.Common.RTEMS-<arch>
[Andrew Johnson] Add RTEMS-pc368-qemu target, use in Travis-CI builds
[Andrew Johnson] T_A can never contain spaces
[Andrew Johnson] Minor Perl tidying up
[Andrew Johnson] Don't require older RTEMS arch's to set RTEMS_BSP
[Andrew Johnson] Release Notes for the rtems-test branch
[Andrew Johnson] Fix MUNCH_CMD for RTEMS-pc386 with parallel builds
[Andrew Johnson] RTEMS use non-default osdEnv
[Andrew Johnson] yajlTest doesn't run w/ RTEMS+qemu
[Andrew Johnson] Improve output from genVersionHeader.pl
[Andrew Johnson] Set version to 3.16.2-rc1
[Andrew Johnson] Set version to -DEV after -rc1 tagged
[Andrew Johnson] Clean-up of aai and waveform record sources
[Andrew Johnson] Rework epicsMakeMemFs.pl script to use higher level constructs
[...truncated 2.92 MB...]
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\nodefaultmethods.h(50): note: see declaration of 'epics::pvData::NoDefaultMethods'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaccess.h(182): note: see declaration of 'epics::pvAccess::ChannelRequest'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaccess.h(379): warning C4275: non dll-interface class 'epics::pvData::NoDefaultMethods' used as base for dll-interface class 'epics::pvAccess::ChannelFind'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaccess.h(379): note: see declaration of 'epics::pvAccess::ChannelFind'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaccess.h(837): warning C4275: non dll-interface class 'epics::pvData::NoDefaultMethods' used as base for dll-interface class 'epics::pvAccess::Channel'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaccess.h(834): note: see declaration of 'epics::pvAccess::Channel'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaccess.h(1158): warning C4275: non dll-interface class 'epics::pvData::NoDefaultMethods' used as base for dll-interface class 'epics::pvAccess::ChannelProvider'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaccess.h(1157): note: see declaration of 'epics::pvAccess::ChannelProvider'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaccess.h(1249): warning C4275: non dll-interface class 'epics::pvData::NoDefaultMethods' used as base for dll-interface class 'epics::pvAccess::ChannelProviderFactory'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaccess.h(1249): note: see declaration of 'epics::pvAccess::ChannelProviderFactory'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(201): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(260): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(267): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(274): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(281): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(288): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(347): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(356): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(365): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(374): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(386): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(393): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(400): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpvif.cpp(407): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
make[4]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/modules/pva2pva/testApp/O.windows-x64'>
make[4]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/modules/pva2pva/testApp/O.windows-x64'>
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include>        -c pvaLinkTestIoc_registerRecordDeviceDriver.cpp
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include>        -c ../testpvalink.cpp
testpvalink.cpp
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvdata.h(508): warning C4800: 'char': forcing value to bool 'true' or 'false' (performance warning)
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvdata.h(558): warning C4250: 'epics::pvData::PVString': inherits 'epics::pvData::PVScalarValue<std::string>::epics::pvData::PVScalarValue<std::string>::deserialize' via dominance
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvdata.h(461): note: see declaration of 'epics::pvData::PVScalarValue<std::string>::deserialize'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaversion.h(36): warning C4275: non dll-interface class 'epics::pvData::NoDefaultMethods' used as base for dll-interface class 'epics::pvAccess::Version'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaversion.h(36): note: see declaration of 'epics::pvAccess::Version'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaccess.h(104): warning C4275: non dll-interface class 'epics::pvData::NoDefaultMethods' used as base for dll-interface class 'epics::pvAccess::ScopedLock'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaccess.h(104): note: see declaration of 'epics::pvAccess::ScopedLock'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\pvaccess.h(182): warning C4275: non dll-interface class 'epics::pvData::NoDefaultMethods' used as base for dll-interface class 'epics::pvAccess::ChannelRequest'
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include>        -c ../testpdb.cpp
testpdb.cpp
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\configuration.h(46): warning C4275: non dll-interface class 'epics::pvData::NoDefaultMethods' used as base for dll-interface class 'epics::pvAccess::Configuration'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\configuration.h(45): note: see declaration of 'epics::pvAccess::Configuration'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\configuration.h(206): warning C4275: non dll-interface class 'epics::pvData::NoDefaultMethods' used as base for dll-interface class 'epics::pvAccess::ConfigurationProvider'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\configuration.h(205): note: see declaration of 'epics::pvAccess::ConfigurationProvider'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\configuration.h(249): warning C4275: non dll-interface class 'epics::pvData::NoDefaultMethods' used as base for dll-interface class 'epics::pvAccess::ConfigurationFactory'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\include\pv\configuration.h(248): note: see declaration of 'epics::pvAccess::ConfigurationFactory'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\pdbapp\pdbsingle.h(23): warning C4275: non dll-interface struct 'PDBPV' used as base for dll-interface struct 'PDBSinglePV'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\pdbapp\pdb.h(16): note: see declaration of 'PDBPV'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\pdbapp\pdbsingle.h(22): note: see declaration of 'PDBSinglePV'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\pdbapp\pdbgroup.h(74): warning C4275: non dll-interface struct 'PDBPV' used as base for dll-interface struct 'PDBGroupPV'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\pdbapp\pdbgroup.h(73): note: see declaration of 'PDBGroupPV'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\pdbapp\pdbgroup.h(136): warning C4275: non dll-interface struct 'BaseChannel' used as base for dll-interface struct 'PDBGroupChannel'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\common\pvahelper.h(19): note: see declaration of 'BaseChannel'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\pdbapp\pdbgroup.h(136): note: see declaration of 'PDBGroupChannel'
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpdb.cpp(153): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpdb.cpp(168): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpdb.cpp(169): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpdb.cpp(223): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testpdb.cpp(282): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include>        -c ../testdbf_copy.cpp
testdbf_copy.cpp
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testdbf_copy.cpp(204): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testdbf_copy.cpp(225): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testdbf_copy.cpp(144): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testdbf_copy.cpp(253): note: see reference to function template instantiation 'void `anonymous-namespace'::testDBR2PVD_scalar<double,double>(const input_t &,const output_t &)' being compiled
        with
            input_t=double,
            output_t=double
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testdbf_copy.cpp(180): warning C4267: 'argument': conversion from 'size_t' to 'epics::pvData::uint32', possible loss of data
c:\jenkins\win64-1\workspace\epics-7.0-windows\libraries\dll\os\win64\modules\pva2pva\testapp\testdbf_copy.cpp(260): note: see reference to function template instantiation 'void `anonymous-namespace'::testDBR2PVD_enum<epics::pvData::uint32>(const input_t &,epics::pvData::int32)' being compiled
        with
            input_t=epics::pvData::uint32
cl -EHsc -GR           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DNOMINMAX     -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344 -w44251        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/compiler/msvc> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include/os/WIN32> -I<https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/include>        -c ../testgroupconfig.cpp
testgroupconfig.cpp
link -nologo  -LTCG -incremental:no -opt:ref -release  -MACHINE:X64              -out:check_consist.exe   check_consist.obj utilitiesx.obj     <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/Com.lib>
Generating code
Finished generating code
link -nologo  -LTCG -incremental:no -opt:ref -release  -MACHINE:X64              -out:testweak.exe   testweak.obj utilitiesx.obj    <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/Com.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/Com.lib>
Generating code
link -nologo  -LTCG -incremental:no -opt:ref -release  -MACHINE:X64              -out:testtest.exe   testtest.obj utilitiesx.obj     <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/Com.lib>
Generating code
link -nologo  -LTCG -incremental:no -opt:ref -release  -MACHINE:X64              -out:testpvif.exe   testpvif.obj p2pTestIoc_registerRecordDeviceDriver.obj utilitiesx.obj    <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/qsrv.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/Com.lib>
Generating code
link -nologo  -LTCG -incremental:no -opt:ref -release  -MACHINE:X64              -out:testpdb.exe   testpdb.obj p2pTestIoc_registerRecordDeviceDriver.obj utilitiesx.obj    <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/qsrv.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/Com.lib>
Generating code
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/bin/windows-x64/makeTestfile.pl> windows-x64 windows-x64 testweak.t testweak.exe
link -nologo  -LTCG -incremental:no -opt:ref -release  -MACHINE:X64              -out:testpvalink.exe   testpvalink.obj pvaLinkTestIoc_registerRecordDeviceDriver.obj utilitiesx.obj    <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/qsrv.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/Com.lib>
Generating code
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/bin/windows-x64/makeTestfile.pl> windows-x64 windows-x64 testtest.t testtest.exe
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/bin/windows-x64/makeTestfile.pl> windows-x64 windows-x64 testpdb.t testpdb.exe
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/bin/windows-x64/makeTestfile.pl> windows-x64 windows-x64 testpvif.t testpvif.exe
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/bin/windows-x64/makeTestfile.pl> windows-x64 windows-x64 testpvalink.t testpvalink.exe
link -nologo  -LTCG -incremental:no -opt:ref -release  -MACHINE:X64              -out:testgroupconfig.exe   testgroupconfig.obj utilitiesx.obj    <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/qsrv.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/Com.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/Com.lib>
Generating code
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/bin/windows-x64/makeTestfile.pl> windows-x64 windows-x64 testgroupconfig.t testgroupconfig.exe
link -nologo  -LTCG -incremental:no -opt:ref -release  -MACHINE:X64              -out:testdbf_copy.exe   testdbf_copy.obj utilitiesx.obj    <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/qsrv.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/Com.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvAccess.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/pvData.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbRecStd.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/dbCore.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/ca.lib>  <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/lib/windows-x64/Com.lib>
Generating code
perl -CSD <https://jenkins.aps.anl.gov/job/epics-7.0-windows/LIBRARIES=DLL,OS=win64/ws/bin/windows-x64/makeTestfile.pl> windows-x64 windows-x64 testdbf_copy.t testdbf_copy.exe
make -C ./iocBoot install
make -C ./iocwfdemo install
make -C ./iocpvalink install
make -C ./iocimagedemo install
make[4]: Nothing to be done for 'install'.
configure/RULES_DIRS:84: recipe for target 'modules.install' failed
make: *** [modules.install] Error 2
Build step 'Execute Windows batch command' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: epics-7.0-windows » DLL, win64 #62 APS Jenkins via Core-talk
Build failed in Jenkins: epics-7.0-windows » DLL, win64 #60 APS Jenkins
Prev: Build failed in Jenkins: epics-7.0-windows » STATIC,win64 #61 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-7.0-windows » DLL, win32 #61 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-7.0-windows » DLL, win64 #60 APS Jenkins
Next: Build failed in Jenkins: epics-7.0-windows » DLL, win64 #62 APS Jenkins via Core-talk
ANJ, 29 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
