Subject: |
Build failed in Jenkins: epics-7.0 » linux32 #71 |
APS Jenkins via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Sat, 27 Oct 2018 14:22:17 -0500 (CDT) |
See <https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux32/71/display/redirect>
Started by upstream project "epics-7.0" build number 71
originally caused by:
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on linux32-uranus (linux32) in workspace <https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux32/ws/>
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
> git --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
> git fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*
Checking out Revision 818e6c236d6c230790a20ff28fee19004bfa4287 (refs/remotes/origin/7.0)
> git config core.sparsecheckout # timeout=10
> git checkout -f 818e6c236d6c230790a20ff28fee19004bfa4287
Commit message: "Rework epicsMakeMemFs.pl script to use higher level constructs"
> git rev-list --no-walk 818e6c236d6c230790a20ff28fee19004bfa4287 # timeout=10
Cleaning workspace
> git rev-parse --verify HEAD # timeout=10
Resetting working tree
> git reset --hard # timeout=10
> git clean -fdx # timeout=10
> git submodule foreach --recursive git reset --hard # timeout=10
> git submodule foreach git clean -fdx # timeout=10
> git remote # timeout=10
> git submodule init # timeout=10
> git submodule sync # timeout=10
> git config --get remote.origin.url # timeout=10
> git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
> git config --get submodule.modules/pvData.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
> git submodule update modules/pvData
> git config --get submodule.modules/pvAccess.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
> git submodule update modules/pvAccess
> git config --get submodule.modules/normativeTypes.url # timeout=10
> git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
> git submodule update modules/normativeTypes
> git config --get submodule.modules/pvaClient.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
> git submodule update modules/pvaClient
> git config --get submodule.modules/pvDatabase.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
> git submodule update modules/pvDatabase
> git config --get submodule.modules/pva2pva.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
> git submodule update modules/pva2pva
[linux32] $ /bin/sh -xe /tmp/jenkins1526677469011092229.sh
+ csac=configure/os/CONFIG_SITE.linux-x86.Common
+ echo 'CROSS_COMPILER_TARGET_ARCHS :='
+ case $EPICS_HOST_ARCH in
+ echo 'CROSS_COMPILER_TARGET_ARCHS += linux-arm'
+ EXTRA=-j3
+ -O
/tmp/jenkins1526677469011092229.sh: line 15: -O: command not found
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.*/*.tap
Did not find any matching files.
- Jenkins build is back to normal : epics-7.0 » linux32 #72 APS Jenkins via Core-talk
Build failed in Jenkins: epics-7.0-windows » DLL, win32 #61 APS Jenkins via Core-talk
Build failed in Jenkins: epics-7.0 » linux64 #71 APS Jenkins via Core-talk
<2018>
2025
2026
Re: pvget -m timeout after first value Johnson, Andrew N. via Core-talk
<2018>
2025
2026
