2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-7.0 » linux64 #71
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Sat, 27 Oct 2018 14:22:24 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux64/71/display/redirect>
Started by upstream project "epics-7.0" build number 71
originally caused by:
 Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building on master in workspace <https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux64/ws/>
 > git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
 > git --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/*
Checking out Revision 818e6c236d6c230790a20ff28fee19004bfa4287 (refs/remotes/origin/7.0)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 818e6c236d6c230790a20ff28fee19004bfa4287
Commit message: "Rework epicsMakeMemFs.pl script to use higher level constructs"
 > git rev-list --no-walk 818e6c236d6c230790a20ff28fee19004bfa4287 # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
 > git submodule foreach --recursive git reset --hard # timeout=10
 > git submodule foreach git clean -fdx # timeout=10
 > git remote # timeout=10
 > git submodule init # timeout=10
 > git submodule sync # timeout=10
 > git config --get remote.origin.url # timeout=10
 > git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
 > git config --get submodule.modules/pvData.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
 > git submodule update --remote modules/pvData
 > git config --get submodule.modules/pvAccess.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
 > git submodule update --remote modules/pvAccess
 > git config --get submodule.modules/normativeTypes.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
 > git submodule update --remote modules/normativeTypes
 > git config --get submodule.modules/pvaClient.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
 > git submodule update --remote modules/pvaClient
 > git config --get submodule.modules/pvDatabase.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
 > git submodule update --remote modules/pvDatabase
 > git config --get submodule.modules/pva2pva.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
 > git submodule update --remote modules/pva2pva
[linux64] $ /bin/sh -xe /tmp/jenkins3014191173433026279.sh
+ csac=configure/os/CONFIG_SITE.linux-x86_64.Common
+ echo 'CROSS_COMPILER_TARGET_ARCHS :='
+ case $EPICS_HOST_ARCH in
+ echo 'CROSS_COMPILER_TARGET_ARCHS += vxWorks-ppc32'
+ echo 'CROSS_COMPILER_TARGET_ARCHS += vxWorks-ppc32sf'
+ echo 'CROSS_COMPILER_TARGET_ARCHS += RTEMS-uC5282'
+ EXTRA=-j4
+ -O
/tmp/jenkins3014191173433026279.sh: line 11: -O: command not found
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.*/*.tap
Did not find any matching files.
Jenkins build is unstable: epics-7.0 » linux64 #72 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-7.0 » linux32 #71 APS Jenkins via Core-talk
Next: Jenkins build is unstable: epics-7.0 » linux64 #72 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-7.0 » linux32 #72 APS Jenkins via Core-talk
ANJ, 27 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
