2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: R7.0.2-rc1 tagged and published at APS
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
To: EPICS core-talk <[email protected]>
Date: Thu, 1 Nov 2018 23:12:00 +0000
I don't have time to write the full announcement now (need to do 3.16.2
as well), but I did create the 7.0.2-rc1 release earlier and pull out
and format all the documentation for the APS EPICS website.
    https://epics.anl.gov/base/R7-0/2.php
Alert: On some systems the new netget test program that I added to the
modules/database/test/std/rec directory has been known to hang. This is
a Perl script that starts and interacts with a running soft IOC process
and also runs both caget and pvget to confirm the network operations are
working properly. It is configuring everything to use localhost only,
and the hang may be an interaction between Perl and the iocsh command-
line. I will fix or disable this before the final release; it is
mentioned in the Known Problems page already.
- Andrew
Re: R7.0.2-rc1 tagged and published at APS Dirk Zimoch
Prev: Build failed in Jenkins: epics-7.0-windows » DLL, win64 #68 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-7.0-windows » DLL,win64 #69 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-7.0-windows » DLL,win64 #69 APS Jenkins via Core-talk
Next: Re: R7.0.2-rc1 tagged and published at APS Dirk Zimoch
ANJ, 02 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
