2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R7.0.2-rc1 tagged and published at APS
To: <[email protected]>
Date: Fri, 2 Nov 2018 11:01:23 +0100
Hi Andrew,
It seems I have a hanging test in 3.15 as well
make[3]: Entering directory `/jenkins/workspace/EPICS-3.15/src/ioc/db/test/O.RHEL7-x86_64' perl -CSD -MTest::Harness -e 'runtests @ARGV if @ARGV;' dbShutdownTest.t dbPutLinkTest.t dbLockTest.t testdbConvert.t callbackTest.t callbackParallelTest.t dbStateTest.t dbCaStatsTest.t scanIoTest.t dbChannelTest.t dbChArrTest.t chfPluginTest.t arrShorthandTest.t recGblCheckDeadbandTest.t testPutGetTest.t
dbShutdownTest.t ........... ok
dbPutLinkTest.t ............ ok
dbLockTest.t ............... ok
testdbConvert.t ............ ok
callbackTest.t ............. ok
callbackParallelTest.t ..... ok
dbStateTest.t .............. ok
dbCaStatsTest.t ............ ok
Starting iocInit
Starting iocInit
[Hangs here]
If I am running the tests for different EPICS versions on the same Jenkins server, can they destructively interfere if the tests happen to run at the same time? In that case I better change the Jenkins configuration to use only 1 worker.
Dirk
On 02.11.2018 00:12, Johnson, Andrew N. via Core-talk wrote:
I don't have time to write the full announcement now (need to do 3.16.2
as well), but I did create the 7.0.2-rc1 release earlier and pull out
and format all the documentation for the APS EPICS website.
     https://epics.anl.gov/base/R7-0/2.php
Alert: On some systems the new netget test program that I added to the
modules/database/test/std/rec directory has been known to hang. This is
a Perl script that starts and interacts with a running soft IOC process
and also runs both caget and pvget to confirm the network operations are
working properly. It is configuring everything to use localhost only,
and the hang may be an interaction between Perl and the iocsh command-
line. I will fix or disable this before the final release; it is
mentioned in the Known Problems page already.
- Andrew
Re: hanging test in 3.15 Johnson, Andrew N. via Core-talk
R7.0.2-rc1 tagged and published at APS Johnson, Andrew N. via Core-talk
Prev: Jenkins build is back to normal : epics-7.0-windows » DLL,win64 #69 APS Jenkins via Core-talk
Next: Problem with cross-tests Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: R7.0.2-rc1 tagged and published at APS Johnson, Andrew N. via Core-talk
Next: Re: hanging test in 3.15 Johnson, Andrew N. via Core-talk
ANJ, 02 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
