See <http://gfa-sls2-test:8080/job/EPICS-7/160/display/redirect?page=changes>
Changes:
[mdavidsaver] rsrv: suppress repeated UDP error messages
[mdavidsaver] ca: suppress repeated UDP error messages
[mdavidsaver] rsrv: avoid redundant getpeername()
[mdavidsaver] epicsThreadRealtimeLock: clarify errors
[mdavidsaver] RTEMS: add zoneset()
[mdavidsaver] asLib add asInitMem()
[mdavidsaver] add aslibtest
[...truncated 16.75 MB...]
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64 RHEL7-x86_64 testweak.t testweak
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64 RHEL7-x86_64 testtest.t testtest
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64 RHEL7-x86_64 testpvif.t testpvif
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64 RHEL7-x86_64 testpdb.t testpdb
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64 RHEL7-x86_64 testpvalink.t testpvalink
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64 RHEL7-x86_64 testgroupconfig.t testgroupconfig
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64 RHEL7-x86_64 testdbf_copy.t testdbf_copy
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/check_consist>
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.RHEL7-x86_64'>
make -C O.RHEL7-x86_64-clang -f ../Makefile TOP=../.. \
T_A=RHEL7-x86_64-clang install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.RHEL7-x86_64-clang'>
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF check_consist.d ../check_consist.cpp
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testdbf_copy.d ../testdbf_copy.cpp
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testgroupconfig.d ../testgroupconfig.cpp
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/registerRecordDeviceDriver.pl> -I. -I.. -I../O.Common -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/dbd> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/dbd> -o pvaLinkTestIoc_registerRecordDeviceDriver.cpp ../O.Common/pvaLinkTestIoc.dbd pvaLinkTestIoc_registerRecordDeviceDriver <http://gfa-sls2-test:8080/job/EPICS-7/ws/>
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF pvaLinkTestIoc_registerRecordDeviceDriver.d pvaLinkTestIoc_registerRecordDeviceDriver.cpp
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpvalink.d ../testpvalink.cpp
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/registerRecordDeviceDriver.pl> -I. -I.. -I../O.Common -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/dbd> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/dbd> -o p2pTestIoc_registerRecordDeviceDriver.cpp ../O.Common/p2pTestIoc.dbd p2pTestIoc_registerRecordDeviceDriver <http://gfa-sls2-test:8080/job/EPICS-7/ws/>
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF p2pTestIoc_registerRecordDeviceDriver.d p2pTestIoc_registerRecordDeviceDriver.cpp
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpdb.d ../testpdb.cpp
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpvif.d ../testpvif.cpp
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testtest.d ../testtest.cpp
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testweak.d ../testweak.cpp
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF utilitiesx.d ../utilitiesx.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.RHEL7-x86_64-clang'>
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../check_consist.cpp
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../utilitiesx.cpp
clang++ -o check_consist -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -rdynamic check_consist.o utilitiesx.o -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testweak.cpp
clang++ -o testweak -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -rdynamic testweak.o utilitiesx.o -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testtest.cpp
clang++ -o testtest -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -rdynamic testtest.o utilitiesx.o -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testpvif.cpp
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c p2pTestIoc_registerRecordDeviceDriver.cpp
clang++ -o testpvif -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -rdynamic testpvif.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testpdb.cpp
clang++ -o testpdb -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -rdynamic testpdb.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testpvalink.cpp
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c pvaLinkTestIoc_registerRecordDeviceDriver.cpp
clang++ -o testpvalink -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -rdynamic testpvalink.o pvaLinkTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testgroupconfig.cpp
clang++ -o testgroupconfig -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -rdynamic testgroupconfig.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
clang++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testdbf_copy.cpp
clang++ -o testdbf_copy -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -rdynamic testdbf_copy.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64-clang RHEL7-x86_64 testweak.t testweak
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64-clang RHEL7-x86_64 testtest.t testtest
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64-clang RHEL7-x86_64 testpvif.t testpvif
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64-clang RHEL7-x86_64 testpdb.t testpdb
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64-clang RHEL7-x86_64 testpvalink.t testpvalink
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64-clang RHEL7-x86_64 testgroupconfig.t testgroupconfig
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> RHEL7-x86_64-clang RHEL7-x86_64 testdbf_copy.t testdbf_copy
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64-clang/check_consist>
make -C O.SL6-x86_64 -f ../Makefile TOP=../.. \
T_A=SL6-x86_64 install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.SL6-x86_64'>
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF check_consist.d ../check_consist.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testdbf_copy.d ../testdbf_copy.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testgroupconfig.d ../testgroupconfig.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF pvaLinkTestIoc_registerRecordDeviceDriver.d pvaLinkTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpvalink.d ../testpvalink.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF p2pTestIoc_registerRecordDeviceDriver.d p2pTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpdb.d ../testpdb.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpvif.d ../testpvif.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testtest.d ../testtest.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testweak.d ../testweak.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF utilitiesx.d ../utilitiesx.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.SL6-x86_64'>
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../check_consist.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../utilitiesx.cpp
/usr/bin/g++44 -o check_consist -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -L /usr/lib/x86_64-redhat-linux6E/lib64 -rdynamic -m64 check_consist.o utilitiesx.o -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testweak.cpp
/usr/bin/g++44 -o testweak -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -L /usr/lib/x86_64-redhat-linux6E/lib64 -rdynamic -m64 testweak.o utilitiesx.o -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testtest.cpp
/usr/bin/g++44 -o testtest -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -L /usr/lib/x86_64-redhat-linux6E/lib64 -rdynamic -m64 testtest.o utilitiesx.o -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testpvif.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c p2pTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++44 -o testpvif -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -L /usr/lib/x86_64-redhat-linux6E/lib64 -rdynamic -m64 testpvif.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testpdb.cpp
<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/anyscalar.h>: In function ‘void<unnamed>::testGroupPut(pvac::ClientProvider&)’:
<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/anyscalar.h>:111: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/anyscalar.h>:111: note: initialized from here
/usr/bin/g++44 -o testpdb -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -L /usr/lib/x86_64-redhat-linux6E/lib64 -rdynamic -m64 testpdb.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testpvalink.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c pvaLinkTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++44 -o testpvalink -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -L /usr/lib/x86_64-redhat-linux6E/lib64 -rdynamic -m64 testpvalink.o pvaLinkTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testgroupconfig.cpp
/usr/bin/g++44 -o testgroupconfig -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -L /usr/lib/x86_64-redhat-linux6E/lib64 -rdynamic -m64 testgroupconfig.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_64_ -DUNIX -Dlinux -O3 -Wall -m64 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testdbf_copy.cpp
/usr/bin/g++44 -o testdbf_copy -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -L /usr/lib/x86_64-redhat-linux6E/lib64 -rdynamic -m64 testdbf_copy.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86_64 RHEL7-x86_64 testweak.t testweak
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86_64 RHEL7-x86_64 testtest.t testtest
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86_64 RHEL7-x86_64 testpvif.t testpvif
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86_64 RHEL7-x86_64 testpdb.t testpdb
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86_64 RHEL7-x86_64 testpvalink.t testpvalink
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86_64 RHEL7-x86_64 testgroupconfig.t testgroupconfig
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86_64 RHEL7-x86_64 testdbf_copy.t testdbf_copy
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/SL6-x86_64/check_consist>
make -C O.SL6-x86 -f ../Makefile TOP=../.. \
T_A=SL6-x86 install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.SL6-x86'>
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF check_consist.d ../check_consist.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testdbf_copy.d ../testdbf_copy.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testgroupconfig.d ../testgroupconfig.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF pvaLinkTestIoc_registerRecordDeviceDriver.d pvaLinkTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpvalink.d ../testpvalink.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF p2pTestIoc_registerRecordDeviceDriver.d p2pTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpdb.d ../testpdb.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpvif.d ../testpvif.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testtest.d ../testtest.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testweak.d ../testweak.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF utilitiesx.d ../utilitiesx.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.SL6-x86'>
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../check_consist.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../utilitiesx.cpp
/usr/bin/g++44 -o check_consist -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -L /usr/lib/x86_64-redhat-linux6E/lib -rdynamic -m32 check_consist.o utilitiesx.o -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testweak.cpp
/usr/bin/g++44 -o testweak -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -L /usr/lib/x86_64-redhat-linux6E/lib -rdynamic -m32 testweak.o utilitiesx.o -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testtest.cpp
/usr/bin/g++44 -o testtest -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -L /usr/lib/x86_64-redhat-linux6E/lib -rdynamic -m32 testtest.o utilitiesx.o -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testpvif.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c p2pTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++44 -o testpvif -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -L /usr/lib/x86_64-redhat-linux6E/lib -rdynamic -m32 testpvif.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testpdb.cpp
/usr/bin/g++44 -o testpdb -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -L /usr/lib/x86_64-redhat-linux6E/lib -rdynamic -m32 testpdb.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testpvalink.cpp
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c pvaLinkTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++44 -o testpvalink -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -L /usr/lib/x86_64-redhat-linux6E/lib -rdynamic -m32 testpvalink.o pvaLinkTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testgroupconfig.cpp
/usr/bin/g++44 -o testgroupconfig -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -L /usr/lib/x86_64-redhat-linux6E/lib -rdynamic -m32 testgroupconfig.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
/usr/bin/g++44 -D_GNU_SOURCE -D_DEFAULT_SOURCE -isystem /usr/lib/x86_64-redhat-linux6E/include -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -D_X86_ -DUNIX -Dlinux -O3 -Wall -march=i686 -m32 -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testdbf_copy.cpp
/usr/bin/g++44 -o testdbf_copy -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -L /usr/lib/x86_64-redhat-linux6E/lib -rdynamic -m32 testdbf_copy.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testweak.t testweak
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testtest.t testtest
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testpvif.t testpvif
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testpdb.t testpdb
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testpvalink.t testpvalink
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testgroupconfig.t testgroupconfig
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testdbf_copy.t testdbf_copy
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/SL6-x86/check_consist>
make -C O.yocto21-aarch64 -f ../Makefile TOP=../.. \
T_A=yocto21-aarch64 install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.yocto21-aarch64'>
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF check_consist.d ../check_consist.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testdbf_copy.d ../testdbf_copy.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testgroupconfig.d ../testgroupconfig.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF pvaLinkTestIoc_registerRecordDeviceDriver.d pvaLinkTestIoc_registerRecordDeviceDriver.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpvalink.d ../testpvalink.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF p2pTestIoc_registerRecordDeviceDriver.d p2pTestIoc_registerRecordDeviceDriver.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpdb.d ../testpdb.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpvif.d ../testpvif.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testtest.d ../testtest.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testweak.d ../testweak.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF utilitiesx.d ../utilitiesx.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.yocto21-aarch64'>
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../check_consist.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../utilitiesx.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o check_consist -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -rdynamic check_consist.o utilitiesx.o -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testweak.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testweak -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -rdynamic testweak.o utilitiesx.o -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testtest.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testtest -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -rdynamic testtest.o utilitiesx.o -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testpvif.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c p2pTestIoc_registerRecordDeviceDriver.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testpvif -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -rdynamic testpvif.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testpdb.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testpdb -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -rdynamic testpdb.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testpvalink.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c pvaLinkTestIoc_registerRecordDeviceDriver.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testpvalink -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -rdynamic testpvalink.o pvaLinkTestIoc_registerRecordDeviceDriver.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testgroupconfig.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testgroupconfig -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -rdynamic testgroupconfig.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -DUNIX -Dlinux -O3 -Wall -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testdbf_copy.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testdbf_copy -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux -rdynamic testdbf_copy.o utilitiesx.o -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testweak.t testweak
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testtest.t testtest
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testpvif.t testpvif
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testpdb.t testpdb
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testpvalink.t testpvalink
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testgroupconfig.t testgroupconfig
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testdbf_copy.t testdbf_copy
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/yocto21-aarch64/check_consist>
make -C O.V67-ppc604 -f ../Makefile TOP=../.. \
T_A=V67-ppc604 install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.V67-ppc604'>
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DCPU=PPC604 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h -O2 -Wall -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>' -fno-builtin -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM > utilitiesx.d ../utilitiesx.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.V67-ppc604'>
make -C O.V63-ppc603 -f ../Makefile TOP=../.. \
T_A=V63-ppc603 install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.V63-ppc603'>
/afs/psi.ch/project/vxworks/VxWorks6.3/gnu/3.4.4-vxworks-6.3/x86-linux2/bin/ccppc -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DCPU=PPC603 -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/vxWorks.h -O2 -Wall -mcpu=603 -mstrict-align -mlongcall -Wno-uninitialized -fno-builtin -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.3/vxworks-6.3/target/h/wrn/coreip -MM > utilitiesx.d ../utilitiesx.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.V63-ppc603'>
make -C O.moxa42-armv6l -f ../Makefile TOP=../.. \
T_A=moxa42-armv6l install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.moxa42-armv6l'>
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF check_consist.d ../check_consist.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testdbf_copy.d ../testdbf_copy.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testgroupconfig.d ../testgroupconfig.cpp
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/registerRecordDeviceDriver.pl> -I. -I.. -I../O.Common -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/dbd> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/dbd> -o pvaLinkTestIoc_registerRecordDeviceDriver.cpp ../O.Common/pvaLinkTestIoc.dbd pvaLinkTestIoc_registerRecordDeviceDriver <http://gfa-sls2-test:8080/job/EPICS-7/ws/>
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF pvaLinkTestIoc_registerRecordDeviceDriver.d pvaLinkTestIoc_registerRecordDeviceDriver.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpvalink.d ../testpvalink.cpp
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/registerRecordDeviceDriver.pl> -I. -I.. -I../O.Common -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/dbd> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/dbd> -o p2pTestIoc_registerRecordDeviceDriver.cpp ../O.Common/p2pTestIoc.dbd p2pTestIoc_registerRecordDeviceDriver <http://gfa-sls2-test:8080/job/EPICS-7/ws/>
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF p2pTestIoc_registerRecordDeviceDriver.d p2pTestIoc_registerRecordDeviceDriver.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpdb.d ../testpdb.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testpvif.d ../testpvif.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testtest.d ../testtest.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF testweak.d ../testweak.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -MM -MF utilitiesx.d ../utilitiesx.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp/O.moxa42-armv6l'>
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../check_consist.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../utilitiesx.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -o check_consist -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/moxa42-armv6l> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/moxa42-armv6l> -Wl,-rpath-link,/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/arm-none-linux-gnueabi/lib -Wl,-rpath-link,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/moxa42-armv6l> -rdynamic check_consist.o utilitiesx.o -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common -DUNIX -Dlinux -O3 -Wall -funwind-tables -Wno-psabi -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -c ../testweak.cpp
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/arm-g++ -o testweak -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/moxa42-armv6l> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/moxa42-armv6l> -Wl,-rpath-link,/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/arm-none-linux-gnueabi/lib -Wl,-rpath-link,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/moxa42-armv6l> -rdynamic testweak.o utilitiesx.o -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/afs/psi.ch/project/embeddedlinux/moxa/arm-linux-4.4.2-v4/bin/../libexec/gcc/arm-none-linux-gnueabi/4.4.2/ld: final link failed: No space left on device
collect2: ld returned 1 exit status
make[4]: *** [testweak] Error 1
make[3]: *** [install.moxa42-armv6l] Error 2
make[3]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/testApp'>
make[2]: *** [testApp.install] Error 2
make[2]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva'>
make[1]: *** [pva2pva.install] Error 2
make[1]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules'>
make: *** [modules.install] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
- Jenkins build is back to normal : EPICS-7 #161 Jenkins EPICS PSI
Re: Issues with latest version of base-7.0 Marty Kraimer
Compression in pvAccess Mark Rivers
<2018>
2025
2026
Jenkins build is back to stable : epics-7.0 » linux32 #84 APS Jenkins via Core-talk
<2018>
2025
2026
