2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Issues with latest version of base-7.0
To: [email protected]
Date: Thu, 15 Nov 2018 14:54:57 -0500
On 11/14/18 10:17 PM, Johnson, Andrew N. via Core-talk wrote:
@Michael: call it experience of too many encounters with Murphy’s law...
I don’t think it’s worth using a debugger, this is probably because of the slightly unusual behavior of the busy record, which I didn’t really think about or test with this change. The synapps busy record explicitly allows the database to determine when processing is complete and hence when to fire put-completion; you should probably take a look at the busy::process() routine to understand it.
It has been suggested that we should add the busy record or something like it to base. Marty has a simple kind of busy record in the exampleCpp module.
That is a really simple busy record and is most likely not appropriate for base. I suspect that there are applications that rely on semantics of the busy record from synapps.
Marty
I will look at Mark’s build issue when I get a chance, someone else here has also reported this, which is purely a warning message that I added but will probably disable for the final release.
- Andrew
Issues with latest version of base-7.0 Mark Rivers
Re: Issues with latest version of base-7.0 Michael Davidsaver
Re: Issues with latest version of base-7.0 Johnson, Andrew N. via Core-talk
Prev: Jenkins build is still unstable: epics-7.0 » linux32 #83 APS Jenkins via Core-talk
Next: Build failed in Jenkins: EPICS-7 #160 Jenkins EPICS PSI
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Issues with latest version of base-7.0 Johnson, Andrew N. via Core-talk
Next: RE: Issues with latest version of base-7.0 Mark Rivers via Core-talk
ANJ, 19 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
