2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 64-bit records
From: "Williams Jr., Ernest L. via Core-talk" <[email protected]>
To: Timo Korhonen <[email protected]>
Date: Tue, 8 Jan 2019 15:58:03 +0000
Hi Timo,
Response below
From: [email protected] <[email protected]> on behalf of Timo Korhonen via Core-talk <[email protected]>
Sent: Tuesday, January 8, 2019 3:08 AM
To: EPICS Core Talk
Subject: 64-bit records
Hi all,
I made a quick try to use the 64-bit record types (int64in/int64out) with base 7.0.2.
Trying to pvget the record, I get the following message on the IOC console:
epics> 2019-01-08T11:43:50.309 an exception caught while in receiveThread at ../../src/remote/codec.cpp:1144: Unsupported DBR code
And pvget times out. With caget, I can read the value but as expected, I do not get the 64-bit integer (because ca does not support it, obviously).
Any ideas? Maybe I am missing some configuration, but I could not figure out from the release notes if I needed to do something extra.
This is on Mac OSX El Capitan, 10.11.6. I can try other platforms later but at the first sight this does not appear to be a platform-specific issue.
>>>>:  ELW:
I would also like to try this on my platforms here at SLAC.
Can you share what you have for your IOC?
E.g.  <TOP>/xxxApp/src/Makefile
         <TOP>/xxxApp/Db/*.db
         <TOP>/iocBoot/<ioc>/st.cmd
ernesto@localhost  (7.0) $ pwd
/usr/local/controls/epics/base/R7.0.2/dbd
ernesto@localhost  (7.0) $ grep int64in *
devSoft.dbd:device(int64in,CONSTANT,devI64inSoft,"Soft Channel")
devSoft.dbd:device(int64in,CONSTANT,devI64inSoftCallback,"Async Soft Channel")
int64inRecord.dbd:recordtype(int64in) {
softIoc.dbd:recordtype(int64in) {
softIoc.dbd:device(int64in, CONSTANT, devI64inSoft, "Soft Channel")
softIoc.dbd:device(int64in, CONSTANT, devI64inSoftCallback, "Async Soft Channel")
softIocPVA.dbd:recordtype(int64in) {
softIocPVA.dbd:device(int64in, CONSTANT, devI64inSoft, "Soft Channel")
softIocPVA.dbd:device(int64in, CONSTANT, devI64inSoftCallback, "Async Soft Channel")
stdRecords.dbd:include "int64inRecord.dbd"
Cheers,
Ernesto
Timo
Re: 64-bit records Michael Davidsaver via Core-talk
64-bit records Timo Korhonen via Core-talk
Prev: 64-bit records Timo Korhonen via Core-talk
Next: Re: 64-bit records Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 08 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
