2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 64-bit records
From: Michael Davidsaver via Core-talk <[email protected]>
To: Timo Korhonen <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Tue, 8 Jan 2019 08:00:22 -0800
On 1/8/19 3:08 AM, Timo Korhonen via Core-talk wrote:
> Hi all,
> I made a quick try to use the 64-bit record types (int64in/int64out) with base 7.0.2.
> Trying to pvget the record, I get the following message on the IOC console:
> epics> 2019-01-08T11:43:50.309 an exception caught while in receiveThread at ../../src/remote/codec.cpp:1144: Unsupported DBR code
https://github.com/search?q=%22Unsupported+DBR+code%22&type=Code
points to QSRV.
> And pvget times out. With caget, I can read the value but as expected, I do not get the 64-bit integer (because ca does not support it, obviously).
> Any ideas? Maybe I am missing some configuration, but I could not figure out from the release notes if I needed to do something extra.
No, this is probably a regression on my part.  I thought I had added
tests with the int64in/out record types, but apparently I have not (yet).
> This is on Mac OSX El Capitan, 10.11.6. I can try other platforms later but at the first sight this does not appear to be a platform-specific issue.
> Timo
Re: 64-bit records Timo Korhonen via Core-talk
Prev: Re: 64-bit records Williams Jr., Ernest L. via Core-talk
Next: Re: 64-bit records Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 64-bit records Michael Davidsaver via Core-talk
Next: Re: 64-bit records Timo Korhonen via Core-talk
ANJ, 09 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
