2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Int64 PV and caget
From: "Williams Jr., Ernest L. via Core-talk" <[email protected]>
To: "Kim, Kukhee" <[email protected]>, "Michael A. Davidsaver" <[email protected]>, "Hill, Bruce" <[email protected]>
Cc: "Slepicka, Hugo Henrique" <[email protected]>, "[email protected]" <[email protected]>
Date: Sat, 12 Jan 2019 04:14:36 +0000
Hi Kukhee,
I wanted to just loop in the core-talk list.
Indeed, I am looking forward to 64-bit support as we can take advantage of it for LCLS II timing system.
Cheers,
Ernest
Sent: Friday, January 11, 2019 1:42 PM
To: Michael A. Davidsaver; Hill, Bruce
Cc: Williams Jr., Ernest L.; Slepicka, Hugo Henrique
Subject: RE: Int64 PV and caget
Hi Michael,
Thank you so much for your explanation.
I am thinking slightly different point of ivew.
I think, we are better to allow the followings:
(1)
record(int64in, "test:ai64") {
    field(VAL, "0xffffffffffffffff")
Because, 0xffffffffffffffff means "-1" in 64bit signed integer. The "-1" is still inside of range and we can accept it to put into the int64 variable.
But, we could not allow the followings:
(2)
record(long, "test:ai32") {
Because, the hex number includes information for bit 0 to bit 63  But there are not  bit 63, bit 62, .... , and bit 32  in 32 bit integer.
Thus, we are better to allow hex number if its number of bits can fit inside data type.
Please, let me know your opinion.
Best regards,
Kukhee
Kukhee Kim | Engineering Physicist
Advanced Controls Department
SLAC National Accelerator Laboratory | Menlo Park, CA
p: 650.926.4912 | m: 669.300.8192 | email: [email protected]
-----Original Message-----
Sent: Friday, January 11, 2019 8:23 AM
To: Kim, Kukhee <[email protected]>; Hill, Bruce <[email protected]>
Cc: Williams Jr., Ernest L. <[email protected]>; Slepicka, Hugo Henrique <[email protected]>
On 1/10/19 4:39 PM, Kim, Kukhee wrote:
> Hi Bruce,
> Thank you for your discussion.
> 1.       Yes, I agree VAL+1 issue came from the losing precession during type conversion to double.
> 2.       “-0x8000000000000000” works. It looks like a parsing issue.
Assignment of out of range field values is now generally not allowed.
An exception is made for the common legacy case of assigning DBF_LONG from a value which is valid DBF_ULONG and vis. versa.
eg.
> record(longin, ....) {
>     field(VAL, "0xffffffff")
strictly speaking is out of range for DBF_LONG, but is allowed as it has been found in the wild (I know I've done this).
This is a legacy behavior for the existing 8, 16, and 32-bit integer fields.  It doesn't extend to the new 64-bit field types, which must be assigned strictly in range.
cf. dbPutStringNum() which is called through dbPutString().
https://github.com/epics-base/epics-base/blob/0ae50485cf3d46185501e18592921c74c8312e6e/modules/database/src/ioc/dbStatic/dbStaticRun.c#L383-L499
Re: Int64 PV and caget Ralph Lange via Core-talk
Prev: EPICS Base 7.x - Known Problems & Patch files Hugo Slepicka via Core-talk
Next: Re: 'Request' support in qsrv Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Base 7.x - Known Problems & Patch files Johnson, Andrew N. via Core-talk
Next: Re: Int64 PV and caget Ralph Lange via Core-talk
ANJ, 17 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
