Hi Ralph,
You must be running dbhcr before iocInit, which outputs nothing for me
either (whereas it works fine after iocInit). This happens because the
new link parser doesn't set plink->type until iocInit, and the code in
dbReportDeviceConfig() [which dbhcr() calls] was expecting it to be set
already.
We can check whether plink->text is set to detect this condition, but we
can't immediately use the contents as the field value because that would
show PV links and constant values as well, which dbhcr is supposed to
ignore. However we can call dbParseLink() to get the link type, and then
for the types it's supposed to display just use the raw plink->text as
the string value.
The result won't be quite as fast since it's now reparsing every link
field before displaying a subset of their values, and the output may be
slightly different since it's now showing the raw text from the .db file
instead of converting the structure fields back to text, but I think it
should be close enough.
See patch (includes formatting changes too, sorry!).
- Andrew
diff --git a/modules/database/src/ioc/dbStatic/dbStaticLib.c b/modules/database/src/ioc/dbStatic/dbStaticLib.c
index 7cc2645..1484e4b 100644
--- a/modules/database/src/ioc/dbStatic/dbStaticLib.c
+++ b/modules/database/src/ioc/dbStatic/dbStaticLib.c
@@ -3556,68 +3556,110 @@ void dbDumpBreaktable(DBBASE *pdbbase,const char *name)
return;
-static char *bus[VXI_IO+1] = {"","","VME","CAMAC","AB",
- "GPIB","BITBUS","","","","","","INST","BBGPIB","VXI"};
-void dbReportDeviceConfig(dbBase *pdbbase,FILE *report)
+static char *bus[LINK_NTYPES] = {
+ "", /* CONSTANT */
+ NULL, /* PV_LINK */
+ "VME",
+ "CAMAC",
+ "AB",
+ "GPIB",
+ "BITBUS",
+ NULL, /* MACRO_LINK */
+ NULL, /* JSON_LINK */
+ NULL, /* PN_LINK */
+ NULL, /* DB_LINK */
+ NULL, /* CA_LINK */
+ "INST",
+ "BBGPIB",
+ "VXI"
+void dbReportDeviceConfig(dbBase *pdbbase, FILE *report)
- DBENTRY dbentry;
- DBENTRY *pdbentry=&dbentry;
- long status;
- char linkValue[messagesize];
- char dtypValue[50];
- char cvtValue[40];
- int ilink,nlinks;
- struct link *plink;
- int linkType;
- FILE *stream = (report==0) ? stdout : report;
+ DBENTRY dbentry, *pdbentry = &dbentry;
+ long status;
+ FILE *stream = report ? report : stdout;
- if(!pdbbase) {
- fprintf(stderr,"pdbbase not specified\n");
- return;
+ if (!pdbbase) {
+ fprintf(stderr, "dbReportDeviceConfig: pdbbase not specified\n");
+ return;
dbInitEntry(pdbbase,pdbentry);
status = dbFirstRecordType(pdbentry);
- while(!status) {
- status = dbFirstRecord(pdbentry);
- while(!status) {
- nlinks = dbGetNLinks(pdbentry);
- for(ilink=0; ilink<nlinks; ilink++) {
- status = dbGetLinkField(pdbentry,ilink);
- if(status || dbGetLinkType(pdbentry)!=DCT_LINK_FORM) continue;
- plink = pdbentry->pfield;
- linkType = plink->type;
- if(bus[linkType][0]==0) continue;
- strncpy(linkValue, dbGetString(pdbentry), NELEMENTS(linkValue)-1);
- linkValue[NELEMENTS(linkValue)-1] = '\0';
- status = dbFindField(pdbentry,"DTYP");
- if(status) break;
- strcpy(dtypValue,dbGetString(pdbentry));
- status = dbFindField(pdbentry,"LINR");
- if(status) {
- cvtValue[0] = 0;
- } else {
- if(strcmp(dbGetString(pdbentry),"LINEAR")!=0) {
- cvtValue[0] = 0;
- } else {
- strcpy(cvtValue,"cvt(");
- status = dbFindField(pdbentry,"EGUL");
- if(!status) strcat(cvtValue,dbGetString(pdbentry));
- status = dbFindField(pdbentry,"EGUF");
- if(!status) {
- strcat(cvtValue,",");
- strcat(cvtValue,dbGetString(pdbentry));
- strcat(cvtValue,")");
- fprintf(stream,"%-8s %-20s %-20s %-20s %-s\n",
- bus[linkType],linkValue,dtypValue,
- dbGetRecordName(pdbentry),cvtValue);
- break;
- status = dbNextRecord(pdbentry);
- status = dbNextRecordType(pdbentry);
+ while (!status) {
+ const int nlinks = dbGetNLinks(pdbentry);
+ status = dbFirstRecord(pdbentry);
+ while (!status) {
+ int ilink;
+ for (ilink=0; ilink<nlinks; ilink++) {
+ char linkValue[messagesize];
+ char dtypValue[50];
+ char cvtValue[40];
+ struct link *plink;
+ int linkType;
+ status = dbGetLinkField(pdbentry, ilink);
+ if (status)
+ continue;
+ plink = pdbentry->pfield;
+ linkType = plink->type;
+ if (plink->text) { /* Not yet parsed */
+ dbLinkInfo linfo;
+ if (dbParseLink(plink->text, pdbentry->pflddes->field_type, &linfo))
+ continue;
+ linkType = linfo.ltype;
+ if (linkType && bus[linkType])
+ strncpy(linkValue, plink->text, messagesize-1);
+ dbFreeLinkInfo(&linfo);
+ else {
+ strncpy(linkValue, dbGetString(pdbentry), messagesize-1);
+ if (!linkType || !bus[linkType])
+ continue;
+ linkValue[messagesize-1] = '\0';
+ status = dbFindField(pdbentry, "DTYP");
+ if (status)
+ break; /* Next record type */
+ strcpy(dtypValue, dbGetString(pdbentry));
+ status = dbFindField(pdbentry, "LINR");
+ if (status) {
+ cvtValue[0] = 0;
+ else {
+ if (strcmp(dbGetString(pdbentry), "LINEAR") != 0) {
+ cvtValue[0] = 0;
+ else {
+ strcpy(cvtValue,"cvt(");
+ status = dbFindField(pdbentry, "EGUL");
+ if (!status)
+ strcat(cvtValue, dbGetString(pdbentry));
+ status = dbFindField(pdbentry, "EGUF");
+ if (!status) {
+ strcat(cvtValue, ",");
+ strcat(cvtValue, ")");
+ fprintf(stream,"%-8s %-20s %-20s %-20s %-s\n",
+ bus[linkType], linkValue, dtypValue,
+ dbGetRecordName(pdbentry), cvtValue);
+ break;
+ status = dbNextRecord(pdbentry);
+ status = dbNextRecordType(pdbentry);
dbFinishEntry(pdbentry);
finishOutstream(stream);
Re: 'Request' support in qsrv Timo Korhonen via Core-talk
pvAccess monitor & changing request type in same channel Pearson, Matthew R. via Core-talk
<2019>
2025
2026
Re: Int64 PV and caget Williams Jr., Ernest L. via Core-talk
<2019>
2025
2026
