Subject: |
Need changes to makeTesfile.pl for Rtems5 |
"Heinz P. Junkes via Core-talk" <[email protected]> |
To: |
EPICS Core Talk <[email protected]> |
Date: |
Fri, 18 Jan 2019 19:54:36 +0100 |
Unfortunately I have to change something for the new RTEMS when
generating the testfiles in /src/tool/makeTestfile.pl.
What is the most elegant way to do this? I can't tell if I'm doing
Rtems4 or Rtems5 in the script.
Heinz
diff --git a/src/tools/makeTestfile.pl b/src/tools/makeTestfile.pl
index 7d298768f..5408f9e6a 100644
--- a/src/tools/makeTestfile.pl
+++ b/src/tools/makeTestfile.pl
@@ -38,7 +38,8 @@ if( $TA =~ /^win32-x86/ && $HA !~ /^win/ ) {
# Run pc386 test harness w/ QEMU
} elsif( $TA =~ /^RTEMS-pc386-qemu$/ ) {
- $exec = "qemu-system-i386 -m 64 -no-reboot -serial stdio -display
none -net nic,model=ne2k_pci -net user,restrict=yes -kernel $exe";
+ # $exec = "qemu-system-i386 -m 64 -no-reboot -serial stdio -display
+ $exec = "qemu-system-i386 -m 64 -no-reboot -serial stdio -append
\"--console=/dev/com1\" -display none -net nic,model=ne2k_pci -net
# Explicitly fail for other RTEMS targets
} elsif( $TA =~ /^RTEMS-/ ) {
@@ -48,6 +49,7 @@ if( $TA =~ /^win32-x86/ && $HA !~ /^win/ ) {
$exec = "./$exe";
+my $tmp=$exec; $tmp=~s/\"//g;
open(my $OUT, '>', $target) or die "Can't create $target: $!\n";
print $OUT <<EOF;
@@ -59,7 +61,7 @@ use Cwd 'abs_path';
\$ENV{HARNESS_ACTIVE} = 1 if scalar \@ARGV && shift eq '-tap';
\$ENV{TOP} = abs_path(\$ENV{TOP}) if exists \$ENV{TOP};
-system('$exec') == 0 or die "Can't run $exec: \$!\\n";
+system('$exec') == 0 or die "Can't run $tmp: \$!\\n";
EOF
close $OUT or die "Can't close $target: $!\n";
- Re: Need changes to makeTesfile.pl for Rtems5 Johnson, Andrew N. via Core-talk
Re: EPICS Base 7.x - Known Problems & Patch files Johnson, Andrew N. via Core-talk
<2019>
2025
2026
Re: pvAccess monitor & changing request type in same channel Pearson, Matthew R. via Core-talk
<2019>
2025
2026
