2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Strange change in behavior from 7.0.1 to 7.0.2
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>, "Rivers, Mark L." <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 24 Jan 2019 23:49:39 +0000
On 1/24/19 12:54 PM, Michael Davidsaver wrote:
Seems like the best course is for dbProcess() and processTarget()
to keep track of which records are being recursed into.
I hope you aren't considering generating lists or trees of records at runtime...
BTW contrary to what I wrote below RPRO wouldn't need to store the ID, only PUTF would, although unfortunately PUTF is currently visible externally (but is SPC_NOMOD).
I could see of a way around this by storing an identifier in the PUTF and RPRO fields which would let us see that (I'd make the PUTF and RPRO fields into DBF_LONG and use an atomic counter to generate a unique ID for each source put).
I was thinking of using a stack address, or maybe epicsThread*, from the thread which is doing
the processing.  Not really fundamentally different from a global counter, though maybe easier
to debug.  This would be set and cleared by dbProcess().
Just noticed that epicsAtomicIncrIntT() implements undefined behaviour if it wraps because it operates on a signed integer, so we couldn't use that to generate a 'unique-enough' ID anyway.
BTW just changing the 'else if' in processTarget() to this
    else if (psrc->putf && psrc->putf != pdst->putf) {
fixes Mark's database, but breaks asyncproctest:
# ===== Chain 2 again ====== ok 11 - dbPutField("chain2:1.B", 5, ...) -> 0 (Success) ok 12 - dbPutField("chain2:1.B", 5, ...) -> 0 (Success) ok 13 - dbPutField("chain2:1.B", 5, ...) -> 0 (Success) Bail out! Processing timed out Abort
I wonder using if the pointer to the record that received the original put would be sufficiently unique as an ID? When two puts come into the same record before async completion the second put would not set RPRO, but since RPRO is already true we'd just avoid setting it the second time. Using a dbCommon* also allows for even nicer debug/trace messages, we can print the put-record's name in the trace messages in processTarget().
I'm not sure about hijacking the existing flag fields.  Maybe add a new field in dbCommonPvt?
The existing PUTF field is so close to being sufficient; I would much prefer to use it for this than duplicate it, the external visibility is the main problem I see. Any driver/record (such as the tpmac) which writes or writes directly to the field will break, but nobody should be fiddling with dbCommon fields like that.
I'm working on adding a new special() type to allow read-only access to some dbCommon fields that need a little pre-processing — I've wanted to support getting the TIME field for years, so this is just another field to handle in the same way. My dbCommon *PUTF is now working with that...
I don't like hiding per-record data in pvCommonPvt. IMHO the recnode field there should have been another DBF_NOACCESS SPC_NOMOD extra() field added to dbCommon.dbd just like every other IOC subsystem field.
- Andrew
Re: Strange change in behavior from 7.0.1 to 7.0.2 Michael Davidsaver via Core-talk
Strange change in behavior from 7.0.1 to 7.0.2 Mark Rivers via Core-talk
Re: Strange change in behavior from 7.0.1 to 7.0.2 Johnson, Andrew N. via Core-talk
Prev: Re: Strange change in behavior from 7.0.1 to 7.0.2 Michael Davidsaver via Core-talk
Next: Re: Strange change in behavior from 7.0.1 to 7.0.2 Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 25 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
